First post here from a long time lurker. I'm looking to put an antenna on our vehicle to try and extend the range of our Mobile broadband modem. Most of our trips are up,and down the West Coast so am I safe to assume that a higher DB rating antenna would be the way to go?
The Doo crew said
12:04 PM Aug 17, 2015
We run a Telstra 3G hot spot on the standard fibreglass UHF antenna & last trip from Darwin to Albany we had internet in area's where the phones were showing "no service". Were trying out the new 3G-4GX one this year on the same run.
Local bloke recommended not going "too high" in the Db gain as the signal would have a smaller pattern or something along those lines. I looked at the YAGI antennas for more distance but decided against it as a day or two without internet is nice occasionally.
-- Edited by The Doo crew on Monday 17th of August 2015 12:08:27 PM
Have seen them fitted neatly on top of the wineguard. Could be the way to go. Easy installation down through the roof into a cupboard with fittings out of sight. Use plenty of sika or silicone around the entry point.
Ontos45 said
02:46 PM Aug 17, 2015
This is the antenna JPW50 and I use, its telescopic and can be used for mobile and wifi.
Hi all,
https://www.telcoantennas.com.au/site/7m-telescopic-pole-antenna-65dbi
[s the one I use
one on the bulbar and one on the van
Hi Gir some good info here to read and help you understand that I posted previously.
https://telcoantennas.com.au/site/catalog/all-antennas
http://onwireless.com.au/high-gain-850-900-2100-fibreglass-vehicle-marine-antennas-for-nextg-3g-gsm-4g-lte-1800-with-spring-base.html
http://onwireless.com.au/mobile-phone-antennas/apple-iphone-antennas/antenna-patch-cable-for-iphone-4s.html
Cheers Baz
