Hi guys im sticks from West Oz , we have been carravaning for 15 years & enjoy the life style, also fellow carravanners.
I am posting regards Truma (Trauma) hot water system not functioning due to massive water leak. The system is a 2013 model.
Has any body else experienced a problem with theirs?
Coromal repairer suggests a Suburban system, are these any better?
Thanks in anticipation.
mickm said
09:19 PM Jul 31, 2015
I had to replace my boiler last year in a 2010 model. It was leaking through the welded seam. I was on the road and for convenience replaced it with another Truma for $600. I hope a BEST filter when in use and emptying when not in use will prevent it happening again. Should not have happened as the tank is stainless and does not need an anode whereas the suburban needs a replaceable anode. I think we must have had bad ones as I recently went on a rally and at the Q&A session replacing the boiler was one problem that was NOT discussed.
KevKim37 said
11:57 PM Jul 31, 2015
I sent an email to Dometic Head office in Melbourne with regards our Split and leaking tank and they were reasonable in supplying a new tank Kit at a good price.
It's worth a try even with your close to 2 yr old unit because with a Cost of Close to $900 for a complete unit they should last longer than less than 2 yrs
being of Stainless Steel construction.
Cheers Kev.
dragonfly1 said
07:05 AM Aug 1, 2015
It will be only make believe stainless steel from China lucky ours is still ok 2008 model
Dragonfly1
The Doo crew said
12:07 PM Aug 1, 2015
Mines a 2004 model & touch wood no issues with water leaks, just no start due to dust or spider webs in the exhaust port.
Diggings said
10:51 AM Oct 13, 2016
Our Truma has a slow leak running out the air intake for the gas burner, have no idea how I am going to get the hot water system out as van seems to be built around it.
Cheers Kev.
Dragonfly1
