We have a Palsonic TFTV4980MW. We have used it successfully once. On the second go we kept getting a "no signal" message when trying to tune it and ended up with a message that says "Data Base Empty".
We cannot get any channels at all.
Any suggestions please?
Olley46 said
03:20 PM Jul 26, 2015
Carl53 wrote:
Hi,
Hi Carl53
First of all check all leads make shore they are connected properly, then go to ( MENU. ) retune all channels ( auto tune). Needs to be done every time you go to a new location.
Lance C
2weis said
03:38 PM Jul 26, 2015
only time I had problems I discovered I had plugged the aerial lead into the wrong port brian
03_Troopy said
07:55 AM Jul 27, 2015
Are you using the TV in conjunction with a satellite receiver? If so, is the message coming from the satellite receiver and not the TV itself?
Carl53 said
12:58 PM Jul 27, 2015
Thank you all.
I checked the aerial connections and all seemed OK. Was able to go into the menu and click on "reset". I was then able to re tune and it's all go now.
I am still confused though as I am sure I tried reset the last time but kept getting the "database empty" signal.
Carl
brickies said
01:51 PM Jul 27, 2015
I have one of them and you have to retune every stop and make sure if you have a Winegaurd that the button is push in ans green light is lit up .
Gundog said
09:04 AM Jul 30, 2015
I had the same problem, my solution after much checking and trying different cables, i decided to connect a new cable from the antenna directly to tv bingo it located all the channels in the area.
exa41 said
02:54 PM Jul 30, 2015
I couldn't tune in the satelite dish one day and after 2 hours of stuffing around I found the cable ripped out of the external connector,bugger.
03_Troopy said
09:05 AM Jul 31, 2015
Haha, that's not as bad as me trying to pump fuel through my filters, after a filter change, using the little prime knob on top of the filter, with the pre-filter inlet hose disconnected.
Tamey said
10:51 AM Aug 1, 2015
Hi Carl, The bloke next to me had exactly the same problem which drove him nuts until he found it was when he had LED lights on, particularly the 'Touch "lights. When he didn't turn them on, the problem disappeared. Hope this helps
Hi,
Hi Carl53
Lance C
brian
Thank you all.
Carl
