Having trouble tuning a satellite at Uluru, is this normal? I have informed vast rego that I am in NT and they changed the settings but I still cant lock onto a satellite. Maybe in one of those black spots??
Thanks for all and any help
Bas
RodLainie said
01:33 PM Jun 12, 2015
Hi Bas
So long as no trees in way of satellite.settings are lnb 4 horizontal 41 east of north and elevation is 56 hope this helps
Rod
Baz421 said
05:19 PM Jun 12, 2015
RodLainie wrote:
Hi Bas So long as no trees in way of satellite.settings are lnb 4 horizontal 41 east of north and elevation is 56 hope this helps Rod
Hi Bas
my online calculator says C1/D3 is at LNB 41.6 AZ 043 deg mag and ELEV 49.3 deg.
EDIT LNB would be a +41.6 as no minus sign in front.
-- Edited by Baz421 on Friday 12th of June 2015 05:40:18 PM
Baz421 said
05:38 PM Jun 12, 2015
Forgot to ask are you finding any other satellites???? You say it's a tuning problem so assume you are finding C1.
If not check cables - we had a dodgy fitting, I cleaned with PC board spray cleaner, no problems since.
Good scanning.
TommyG said
12:42 PM Jun 13, 2015
There are places where getting a good signal is difficult. We are Sth of Karratha, max signal Quality 50% Max signal level 62% and quite a lot of fine tuning to get that. However picture on all channels is good. I was still on Qld as far as VAST was concerned and thought that was probably the problem, so changed to WA, that made no difference signal quality & level didn't change. Talking to others here all say signal is lacking in this area, some cannot get a picture at all, others get better than we do but not as high as usual. We were at Uluru a couple of years ago, I know we got the TV working but cannot remember the strength.
Bas
Rod
Hi Bas
Here's the link.
http://www.satsig.net/maps/satellite-tv-dish-pointing-australia-new-zealand.htm
We had no problems anywhere there.
Cheers Baz
Good scanning.
