We've a Millard Weekender and keen to dispense with the foam mattress that it came, second hand, with. We're on the South Coast of NSW and a search on Google gives supplies "pick up" from Melbourne. Freight would be a consideration from there and we won't be visiting Melbourne for a year or two. Sydney's fine and we will be in Brisbane in July. We're looking for an inner spring. Any recommendations?
Thanks.
Graeme
-- Edited by harrydiculous on Monday 1st of June 2015 05:47:58 PM
signwilson said
06:25 PM Jun 1, 2015
there is a mob called makin mattresses I am sure they have a shop in Brisbane they make them to order if not there there is one on the gold coast
Firstly -
This mob are not on NSW South Coast by the look of them but are in Newcastle - freight might be cheaper than Melbourne.
Or pick up on the way to QLD or in Brisbane when you get there perhaps.
I think I have seen recommendations for this mob from some on here previously - if not, I am sure we will hear
It is not much good to you I guess, but I used Beds Direct in Epping Vic (Melbourne outer suburb). I have been using their "made to our measure" inner-spring single bed mattresses for almost seven years and they are still like new.
I believe there are a couple of other mattress makers - someone on here will let us know.
done dreaming said
06:40 PM Jun 1, 2015
The question i ask is how to get a double bed inner spring mattress in and out of the van
The Doo crew said
06:52 PM Jun 1, 2015
Went through this process last year, priced many suppliers but freight to the NT tripled the price. Went into a "Clark Rubber" store to get a length of door seal rubber & lo & behold they have inner spring mattresses. Fitted two singles into our almost queen sized bed in the motorhome, super comfortable, great price & good quality.
07:31 PM Jun 1, 2015
Welcome to the gang Graeme, enjoy here and out in the playground.
I only just today after looking around for a week ordered a new comfy made to order innerspring mattress for my van. The two supplied at new were cheap innerspring. The new one is far from cheap but should be worth the $$$$ as I am full time on the road. I am only replacing one mattress though. I had to settle for a size slightly smaller due to the spring system.
I just went into a bed place and one supplier would make to my size needed.
-- Edited by Dougwe on Monday 1st of June 2015 07:31:38 PM
WobblyNut said
08:39 PM Jun 1, 2015
we have two singles in ours , just not quiet enough , we went to Clark rubber .
Bought a queen memory foam mattress , neat cut in two , by clark . Viola.
I started out with th foam on top of th mattress . But switched ,
put th memory foam on th bottom reg mattress on top . You guessed.
Sleep like a top.
John Heddles said
09:10 PM Jun 1, 2015
BT owner with tight access up to the bed due to cupboards and opposite side shower installation. No option to get a full size mattress in.
ALDI had evacuated rolled up innerspring mattresses on sale a couple of weeks ago. Bought two queens - one to try out in the home and one in reserve for the van if the first one worked out OK. So far the trial unit is proving to be more than comfortable so it is likely that the foam mattress is for the scrap heap. Cost is very reasonable - around $200 a unit as I recall - and the comfort is fine.
The rolled up pack is the length of the small side of the mattress and is a doddle to get through to the bed - bit heavy but the box has roller wheels to assist. Only problem will be the need to cut it up to remove it down the track at some stage.
regards,
graeme c said
10:34 PM Jun 1, 2015
Couple of years ago had some narrow single beds made for my van through the sleep doctor in Dapto, they can deliver down the coast
graeme c
NeilandRaine said
07:17 AM Jun 2, 2015
We are also in the market for a new mattress, spoke to Makin Mattresses and they quoted me from $900
Spoke to a woman at Tugerah on the weekend and she said her company makes to measure www.sleepys.com.au/stores. Has stores Newcastle, Sydney, Gold Coast Brisbane and Sunshine coast.
We are in Newcastle
Pondy said
07:18 AM Jun 2, 2015
We got new mattress from Made to Measure Mattresses at 37 Grice Street Clontarf Phone 1300 307 304 Website www.madetomeaasuremattress.com.au There are near Redcliffe in Brisbane
They custom design innerspring caravan mattress
We are very happy with ours. Our van has single beds and they told us exactly how to measure them and they fit perfectly and are very comfortable to sleep on
Flags2 said
10:18 AM Jun 2, 2015
Hi Graeme,
Not sure where you are on the South coast NSW but there are a number of suppliers you might wish to check out. Canberra has makin mattresses and Clarke rubber. Nowra has numerous suppliers as do Batemans Bay and Eden. Memory foam is excellent now with technology advances so you should not dismiss it out of hand.
Here's some contacts.
Luxafoam Batemans Bay (02) 4472 4977
Clarke Rubber Fyshwick (ACT) 02 6280 6818
Makin mattresses Canberra 02 6280 5445
Hope you find something to suit
Robyn
harrydiculous said
11:43 AM Jun 2, 2015
Well, thank you all very much. I didn't expect such a response. Very pleasing. I'll measure up today & see what I can do with the suggestions. I'll put memory Foam back on the list as well.
We're just east of Nowra, (Greenwell Point)
-- Edited by harrydiculous on Tuesday 2nd of June 2015 11:44:49 AM
the pie van said
06:14 AM Jun 3, 2015
i was in the mattress game for 40 yrs and made to measure in clontaff are your best bet. 4" high springs instead of 6" if you want and made in 2 pieces if needed to get into your van. plus of course the ability to choose what ever surface feel you prefer
pete
Hylda&Jon said
11:24 AM Jun 3, 2015
Please remember.
If you are replacing a foam mattress/s with an inner spring one/s you are, most likely, increasing the weight of your caravan by anything from 30kg up to 200kg depending on size and quality of the new mattress.
Hi All,
Thanks.
Graeme
Firstly -
http://www.makinmattresses.com.au/
Sleep like a top.
regards,
graeme c
We are in Newcastle
Hi Graeme,
Robyn
pete
Please remember.
Jon
