I have seen a 2008 Jayco Sterling 25footer dual slide out for sale.
Considering going and have a look.
what should I be looking at to ensure its a good one.
Bruce and Bev said
08:30 AM May 22, 2015
Hi Graham. There are so many things to check over that us amateurs will miss when buying a 'van. Chances are that it being 6 years old, all the faults have been fixed, but the slides might also be ready for some expensive work depending on the amount of use the 'van has had.
Depending on where you are in VIC, there are plenty of caravan repairers around who will inspect the 'van. Shop around for prices for you to take the 'van to them and for them to go to the 'van. Some repairers run a specialist service in pre-purchase of 'vans. Cost should be around $200-$300 tops and they will inspect it all and give you a written report.
Could save you a buying disaster, but good luck anyway !
Bruce
Magnarc said
01:45 PM May 22, 2015
I \f you are around the melbourne eastern siburbs, ADP in Canterbury Rd Kilsyth, can assess it for you.
Bruce
Phil.
