Ratchett type jockey wheel, Do you use / have one. are they any good.
Hey Jim
jade46 said
05:35 PM May 15, 2015
My brother has one on a 18ft Jayco freedom,it wont move the van on grass, the jockey wheel just slips
grahamg said
07:11 PM May 15, 2015
I have one to move a small van, but it only moves it on flat concrete. anything else the wheel just slips. Having said this it is very handy to move the van around on the concrete slab in my garage area.
Wanderlust said
07:51 PM May 15, 2015
I have one with twin tractor type wheels (pump-up). Gets me out of trouble on a slightly sloping concrete driveway. (18ft Jayco Poptop)
-- Edited by Wanderlust on Friday 15th of May 2015 07:52:24 PM
Cruising Cruze said
08:42 PM May 15, 2015
good on concrete or bitumen, forget it to use on grass or gravel
hako said
09:33 PM May 15, 2015
They are called Maco Mules - both single and dual wheels and I have both which perform as mentioned above. I find they allow me to move my van on a slope with some confidence as you can move click by click plus you can easily lock the wheel(s) by pushing the handle up all the way. They are more heavily built than standard jockey wheels but the dual wheel one is damn heavy to carry. Check Gumtree for a 2nd hand one. Cheaper than the electric ones which also slip on grass although with both you can simply put down a sheet of masonite/plywood to get grip on grass.
Good Luck.
Hey Jim said
09:47 PM May 15, 2015
Hi all, thanks for all your replies, sale on at Repco will pick one up. To help my back. I hate getting older before my time.
Regards Jim
03_Troopy said
12:47 AM May 16, 2015
I bought one at a garage sale (yeah I know, I buy lots of stuff at garage sales) for $10. I tried it out on the little Avan and it worked great first time. Next time I used it the ratchet in the head kept slipping. I had a closer look at the head and realised it was just a half inch socket wrench welded into the end of the handle. I had to wait another three or four weeks before I found a half inch socket wrench at another garage sale for $2.00. I ground off the welds on the original head, cut down the handle on the new ratchet head and welded it inot the handle of the jockey wheel. So now it works perfectly
hako said
11:35 AM May 16, 2015
Regards Jim
If it has the hard rubber wheel I'd give it a miss as it will slip even on hard surfaces - the pneumatic tyre grips much better. Some designs necessitate you bending to operate the lever so check that as well.
My double pneumatic wheel Maco Mule surprisingly grips worse than my single wheel version due to the smaller one having morte downward force per sq inch.
Hey Jim said
06:23 PM May 16, 2015
Hi all,
I brought a Repco 10" Jockey wheel with Ratchet 45% off = $117.00 SAVE $112.00 at REPCO till Tommorrow 17th of May.
Has 350kg load Capacity on the jockey, and states can move 2000KG.
It looks the goods to move the new snail, with the GO JACKS under all four wheels as well.
Hi all,
Hey Jim
Good Luck.
Regards Jim
Hi all,
Jim
