the water in the shower is not getting away fast enough, i saw a post and diagram a couple of months ago, on enlarging the outlet pipe can you please put it up for me again thanks
RodLainie said
07:46 PM May 5, 2015
Hi not sure if you have to enlarge the pipe but we found dropping the outlet down a bit lower under the van did the job
Rod
07:54 PM May 5, 2015
One of the problems is not having a continuous drop in your discharge hose. If the hose rises and falls along its route you tend to get air locks under some conditions.
10:44 PM May 5, 2015
As above longer down pipe before any bends. Make the water gravity work.. Check venting in tank ..
Happy Camper said
08:40 AM May 6, 2015
Hi K&J.
I had the same problem and overcome it by simplifying the plumbing and adding a bigger non return valve.
If you go to search box and type in Poor On-suite Shower Drainage you will see how I overcome the problem.
Hope this is of some help.
Cheers, John
Ausmo said
10:18 AM May 6, 2015
Happy Camper wrote:
Hi K&J.
Cheers, John
Hi John
I like your solution. Where did you source your non-return valve?
Erik
Happy Camper said
12:22 PM May 6, 2015
Hi Ausmo,
I purchases the non return valve at Trade Link - Shepparton for about $45 which was ten dollars cheaper than caravan dealer.
Rod
Hi K&J.
Cheers, John
Hi John
Erik
Hi Ausmo,
Cheers, John
