I have the ESC fitted to my Avida Sapphire - the LED indicator lights on drawbar are permantly on when 12 pin plug is inserted, even when ignition is off - is this normal? Even though this is a small draw on power it is my belief that ESC should not draw power without ignition - Avida claim normal and will not provide a wiring diagram for an Auto electrician to check
deverall11 said
10:35 AM Apr 27, 2015
The lights on the indicator are to let you know the system is operational. They have to remain on all the time. If the lights go off, it means ESC is not functioning. You may want to go back to where you had it fitted and ask them to explain the whole thing to you. They should be able to quote examples as to why the lights are off and how to rectify it. It is an integral part of ESC.
Larry
Middo said
03:35 PM Apr 27, 2015
We got ESC fitted on our van and it is on permanently when you put the caravan plug in. Should be protected by a fuse which they should tell you about
pete
moamajohn said
06:34 PM Apr 27, 2015
Yep .My guy said the same too .
Pejay said
07:41 PM Apr 27, 2015
Not sure if the following is connected with the ESC that we too had fitted to our van, but we have noticed on this last trip that our lights on the van appear to have a short in them and 'sparkle' like Christmas lights when Pete has the van hooked up/plugged in to the car. Will check with van dealer on Monday when we put it in for a service.
Possum3 said
07:54 AM Apr 28, 2015
PeJay,
I hope you don't have the same problems as we did - The wiring was causing the van brakes to apply when turning corners - this would of course create a situation where van would stop abrubtly and cause the Tug (Patrol) to be held back and stalling half way around a corner - very hairy! Avida claim that Australian Standards are only recomendations not mandatory.
Phil C said
02:34 PM Apr 28, 2015
Hi guys, I would be interested to find that fuse as my ESC is on the blink as well.
Bruce and Bev said
09:51 PM Apr 28, 2015
our LEDS come on when plug inserted irrespective of ignition on of off. Fitted by a specialist 'van auto-sparkie
Larry
pete
PeJay,
