I know this may sound silly, but I can't find the replies to old posts. please explain in detail as I am new to this.
07:14 AM Apr 16, 2015
Just below where you log in is a thick blue line, click on "search" and type in a few words about what you are looking for, you might need to try different words etc, a list will pop up and choose what you think is the right one. If that doesn't work go to the bottom of each section and just keep scrolling through pages and you might find something.
If all that fails ask your question in the appropriate section i.e. "general" "techies" etc. "Rules and Introduce" is just that.
Keep Safe.
03:04 PM Apr 16, 2015
Griddy, We can see you are a new member by the way you have given much detail in your question. What replies are you enquiring about? Are you referring to replies to topics you have answered?
If you are looking for your old replies you use your Profile to do that. There are two ways you can get to your profile. One is to use the user name "Griddy" under the blue line with "Logged in as" up in the top RH corner of this page, just click onto "Griddy" and that will take you there. The other way is on the blue line below that, Just click onto "User Details" and you will get to the same place. When you are in your profile you will note some panels on the LHS In the "Post" panel you will notice "Member Posts," if you click on that you will find all the reply messages you have posted. Just click on the one you require.
In addition you will see "Topics Started." Occasionally when someone has started a topic and placed it in the wrong forum their thread will be shifted to the correct forum. If that happens to you you can always find your topic by using that (this happens more frequently on other forums but infrequently happens here.)
Whilst you are looking at your profile you will also see another panel on the LHS above the "Posts" one. There are links there to alter your profile. Go into the "Signature" one and create a signature block like Dougwe and I have done. This will let others know a little about you. That can be very handy when someone is answering you and you have not put that info in the text of your question.
Keep Safe.
concise and comprehensive
well done mate
frank
