Hi all
Got a problem with my water tank filler and hose connection on my 2013 25ft Sterling
When both tanks are full and I connect the hose to the hose plug water flows out of the tank fillers
I guess there is a stop valve not working somwhere but not sure how to solve
Any one had a similar problem
Would appreciate some feedback
Cheers Len
Bruce and Bev said
01:35 PM Apr 14, 2015
Len. Why don't you email Jayco with this one? They don't build their RVs as good as they used to, but they provide great after sales and warranty service. They will go out of their way to help you, even though in theory, you are probably out of warranty (Jayco in fact apply a 2 year warranty to their vans - so they tell me)
Treecrest14 said
02:39 PM Apr 14, 2015
Hi Len
I'd suggest you join this forum www.expandasdownunder.com/ and post your query there. It is not just for Expanda van, but any model. They have Jayco staff who monitor the queries there.
Glen
Phil C said
06:31 PM Apr 16, 2015
Gday Len
This is only a suggestion as it sounds like the tanks are over pressure for some reason. There is a connection between the tanks and the normal hose connection (we have a 2013 starcraft) I have had to modify my own connections to something more robust and discovered a one way valve in the hose fill connection, this is to stop water from coming out when on internal tanks. This leads me to believe there is some sort of connection between the two, your story just confirmed it. I did think the two systems were autonomous.
My suggestion is empty the tanks a little via the hand pump over the sink, this may relieve any pressure buildup in the tanks.
Other than that give Jayco a call, I have found them very useful in situations like this.
Glen
Take care and travel safe
