I like the phone, but when you dial a number, it makes an irritatingly loud "ping" as every digit is pushed. Is there a way to stop this? The Nokia manual is no help.
Cheers, Tony
Pam said
07:19 AM Apr 6, 2015
Have you tried google? It says to go to settings then sounds or ringtones look for Key press and uncheck it. Hope this helps.
03_Troopy said
08:25 AM Apr 6, 2015
Try going into "Setting > ringtones+sounds > key press" and see if you can select volume, mute or change it there.
tonyd said
11:49 PM May 29, 2015
Many thanks. So simple! I'm new to these "do everything" phones. But they're fun!
Cheers, Tony
Cheers, Tony
