It says to move the clock back in one spot but then says to spring forward in another spot.
I put my clock back on the back wall but made no difference.
KFT said
09:25 AM Apr 5, 2015
Happy Easter Doug ole mate
I think it means they go forward in spring.
I put my clock back after I had adjusted it
are you still confused?
might ask Dave to explain it over a red or two.
staysafe
11:04 AM Apr 5, 2015
The problem is that picture is the wrong one. The other one should have been posted. The rule is Spring forward and Fall back. I'm sure there should have been two picyures where got that one from.
aussietraveller said
12:33 PM Apr 5, 2015
Don't forget to also change the battery in your smoke detector in both home and van
Hi all
Put your clock back 1 hour tonight as daylight saving ends
Sunday, 5 April 2015, 3:00:00 AM clocks are turned backward 1 hour to
Sunday, 5 April 2015, 2:00:00 AM local standard time instead
Patty
-- Edited by Patty on Saturday 4th of April 2015 09:28:18 PM
-- Edited by Patty on Saturday 4th of April 2015 10:13:58 PM
staysafe
