1. 240 volts from our power points has a fluctuating voltage/current that will send your heart into ventricular fibrillation if you stay connected. Please remember that if you grab hold of a live wire you will not be able to let go. This will KILL you!
2. RCDs and RVDs operate on a difference of current in the two wires (active and neutral) to earth (the third wire) to isolate the supply within a very short time, thus saving your life. There is no protection for inverters and some generators unless there is a RCD or RVD fitted, that will be obvious from the front panel
3. Class one (earthed appliances) and class 2 (square within square) ALL need testing at least once a year. You can be zapped by your toaster, hair dryer etc.
4. If your are STUPID (no apology for that word) to fiddle with even 12volt electrical stuff you are asking for trouble. If you fiddle with 240 volt stuff you have a death wish. CALL a qualified, competent electrician full stop.
5. If you find this post offensive that's good news. It has your attention!
folks, there is a lot more I could say, but honestly I'm sick to death of some crazy things people are doing in their caravans, then they call a sparky to fix their mess.
DONT FIDDLE WITH ELECTRICITY!!!!
-- Edited by Phil C on Wednesday 1st of April 2015 06:57:09 PM
KFT said
07:25 PM Apr 1, 2015
you lookin to start a blue there Phil?
I will second what you have said as a currently licenced sparky of close to 40 years experience.
Should be entertaining Frank, save some of the popcorn for me please mate.
hako said
07:58 PM Apr 1, 2015
Phil - I don't find your post offensive as I know it is posted with good intent, but fair dinkum mate, I'm scared to ask an electrical question so I'll continue playing with electrical things anyway.
Actually electricity is no different to motor vehicles - they both kill and injure with gay abandon especially in the hands of the inexperienced or adventurous and you 'must' be licensed to use them.
Why single out electricity.
Phil C said
08:03 PM Apr 1, 2015
hako wrote:
Phil - I don't find your post offensive as I know it is posted with good intent, but fair dinkum mate, I'm scared to ask an electrical question so I'll continue playing with electrical things anyway. Actually electricity is no different to motor vehicles - they both kill and injure with gay abandon especially in the hands of the inexperienced or adventurous and you 'must' be licensed to use them. Why single out electricity.
Great point mate, BUT some folks think that if you can't see it, it can't hurt you.
I agree with your point. Unqualified laypeople should never fiddle. I don't even do oil changes anymore.
BTW please feel free to ask as many questions as you wish
-- Edited by Phil C on Wednesday 1st of April 2015 08:04:42 PM
08:08 PM Apr 1, 2015
I'm certainly not offended by your thread at all. In fact I find it informative as all should do.
I'm certainly not scared to ask questions if I need to.
iana said
09:04 PM Apr 1, 2015
I'm in my 60's and have worked with smart arsed electricians most of my life. Phil get off your pedestal. There are hundreds of skills out there that are life threatening. Maybe the joke should go like: up in heaven who's the guy playing with the wire with a screw driver and a pair of pliers. Oh that's God making out he's an electrician.
-- Edited by iana on Wednesday 1st of April 2015 09:05:29 PM
jon641 said
10:12 PM Apr 1, 2015
You mostly only get one chance with electricity, if your are lucky, electricians aren't smart arsed, they are trained, there are plenty of would be electricians, mostly in cementries.
12:01 AM Apr 2, 2015
RCD can trip on any "out of balance load" earth or leakage .. Not just earth wire ..
Admittedly in van there's not too many other earths..
oldtrack123 said
12:15 AM Apr 2, 2015
Aus-Kiwi wrote:
RCD can trip on any "out of balance load" earth or leakage .. Not just earth wire .. Admittedly in van there's not too many other earths..
HI
Have you ever actually tested to se how much is "earthed"in a van, camper or motor home??
You may be surprised!!!
Again remember "'EARTHED""does not neccessarily mean 'Mother earth"
,A basic RVD does not monitor current leakage, it is RESIDUAL VOLTAGE sensitive.
but are usually used in conjunction with a RCD & covers loss of isolation & earth leakage
PeterQ
Big Gorilla said
08:28 AM Apr 2, 2015
Most of what Phil says is correct. 240 volt installations in caravans and MHs should only be worked on by a Licenced Electrician. In fact this is the law. Many questions have been asked about 240 volt installations by Forum members in the past, and I made a post some time back that I would give no more advice except to say have a licenced electrician look at it. I don't want to be responsible for giving advice that may result in harm or even death to a member.
03_Troopy said
09:07 AM Apr 2, 2015
It's a fair point for 240V electrical stuff, and to a degree 12V stuff (due to faulty work being liable to cause fires). But most should be kept well clear of RF and data cabling from what I've seen..
Better get some more popcorn KFT
Edit: And don't even get me started on auto sparkies....
-- Edited by 03_Troopy on Thursday 2nd of April 2015 09:12:22 AM
Phil C said
10:56 AM Apr 2, 2015
Hi again,
Thanks for the responses. When I was in the RAAF we were called "queer trades" as you couldnt see anything other than wires, contactors and boxes. The "black handers" ie. engine fitters, airframe fitters etc were non queer trades.
Look I am the first to acknowledge that ALL trades people have dangers and potential death traps BUT these are clear to the eye and easy to avoid, whereas with electrical you need at least a multimeter to see the presence of voltage, and if you use a multimeter wrong you can blow yourself to kingdom come, check youtube for multimeter accidents.
Sorry guys, and with all due respect, anything electrical, RF, UHF, radar etc is double dangerous as you cant see the danger till it kicks your sorry backside.
BTW Electricians give the rules to God!
PS can I have some more popcorn please Frank?
-- Edited by Phil C on Thursday 2nd of April 2015 10:58:26 AM
good points, but how many people ever get their class 1 appl. checked?
Ontos45 said
12:07 PM Apr 2, 2015
Snippet: Please remember that if you grab hold of a live wire you will not be able to let go. This will KILL you!
Depends on what side of neutral the sine wave is, one side it will grab you the other it will throw you away. Found out the hard way when an apprentice, was adjusting a slide on a Logabax mechanical computer and ended up across the room with a smoking melted screwdriver in my hand when driver slipped.
All electricity will kill, even DC, like the electric chair which is DC powered.
Currents with about 50mA through the chest region are considered deadly! Voltage higher than 35Volts overcomes the skins electrical resistance.
(Have my own coloured popcorn snacks thanks )
Phil C said
12:18 PM Apr 2, 2015
Thats just it, if more folks are made aware of this, the more will be sensible enough to get there gear checked, especially the older appliances. I know there will be some who dont give a toss and carry on as if nothing can happen.
I wont be chicken little and say its a must do, but the smart money is on being safe.
BTW testing applies to class one and class two appliances.
madaboutled said
12:25 PM Apr 2, 2015
KFT wrote:
Sure can Phil
will this be enough for now?
Looks like it might be just enough for today, hope you can get more for tomorrow.
Fully agree with Phil and others here on 240v repairs/installations get a licensed electrician. As for 12v, yes you do need to know what you are doing using correct cable sizes to allow for voltage drop, adding breakers and extra fuses, insulating connections etc, etc, etc.... However, you don't need to be a licensed electrician to work on 12v
The following in not intended to offend any 240v Sparky here, BUT, I've seen some doggy "12v" wiring done on a caravan by a "qualified 240v Sparky" using 240v cable that:
A: Was just wrong to start with
B: Wasn't flexible enough for the application
C: Wasn't thick enough to carry the load and wasnt fused.
And the job wasnt on his own van it was for a customer. The whole lot had to be replaced. I have no doubt that licensed electricians know there 240v volt stuff backwards but not all are good with 12v. again not intended to offend any 240v Sparky here, just sayin !. Also I share the sentiments of 03_Troopy, don't even get me started on auto sparkies....
Phil C said
12:43 PM Apr 2, 2015
To quote madaboutled
My response
I agree with your post, there are a number of dodgy sparkies (240V) who will have forgotten their ELV training (ELV = Extra Low Voltage) and Ohm's Law regarding volt drop etc. Before I left teaching we (in conjunction with the office of the technical regulator) tested a group of electricians on basic theory and knowledge (mind you they needed to pass these before they got their qualifications for licencing called the capstone). To all our horror, not many passed. Now im as guilty as all of them, when I completed my training I quickly forgot the theory until I started to teach it.
12 volts needs no licence, correct. Not too sure why this is, I have met a few auto electricians who have NOT been to trade school, their excuse is they learnt off the boss. Mind you we withdrew our work experience kids that day. Maybe its time auto electricians were required to get a licence after trade quals are completed. Now that statement will sure "spark" some discussion.... More popcorn Frank.. lol
See I do have a sense of humour...
Phil C said
12:57 PM Apr 2, 2015
Hi Ontos, to qualify you post. (not sure what a logabax is though)
The time it takes for one cycle at 50 Hz is 20mS, trust me you cant let go (been there done that) it feels like 10 million very large angry ants crawling up your arm, I was lucky I fell backwards and the wire was ripped out of my fingers, thanks goodness for sir Isaac.
I was fiddling with an old B&W TV when I was 13, my Dad told me not to touch the trippler (which creates the very high DC voltage for the tube) I did and ended up with my bottom making a dent in the roller door of our shed. That was very large DC.
You are correct about 50mA, anything above that will start to "cook" vital organs, the frequency plus current will fibrillate the heart and give you a very bad day.
PS I like coloured popcorn too.
01:07 PM Apr 2, 2015
oldtrack123 wrote:
HI
PeterQ
As I said it doesn't have to the earth wire .. we test with temp earth on domestic as its a known earth ..
refereing to earth trip is the old earth leakage circuit breaker type..
power in the annex for example .. Yes residual is what the R is in RCD ...
pomme said
02:02 PM Apr 2, 2015
Remember watching two guys walking along the railway lines over in England about fifty odd years ago, testing the lines with a long handled hammer,
he accidently touched the live rail as he was swinging the hammer (i think the third lines carry 32,000 volts) it sent the hammer flying to i don't know where.
A job i thought they could keep.
Pomme.
oldtrack123 said
02:43 PM Apr 2, 2015
Aus-Kiwi wrote:
[1] admittedly in van there's not too many other earths..
[2 As I said it doesn't have to the earth wire .. we test with temp earth on domestic as its a known earth ..
refereing to
[3] earth trip is the old earth leakage circuit breaker type..
[4]power in the annex for example ..
As I said You may be surprised at how many" earths" are in the average Van ,camper ,motor home.
Sadly many are not aware that the following are more than likely to be "EARTHS"
[1]the whole chassis & any metallic objects attached to it that usually includes metal doors & windows & their frames ,If metal clad the skin
[2]the gas pipe lines & any gas appliance[gas stove]
[3]All class 1 appliances, fridge, aircon ,micro wave , toaster,electric jug /kettle ,etc
[4]Possiibly the stainless steel wash up sink & taps
The true situation would be that almost anywhere you stand EARTHS are within reach!!]
EVEN if the extension lead is not plugged, but a generator or inverter is plugged into the power inlet socket
The old ELCBs[1960s] as used in the general electrical area, worked on exactly the same principle as today's RCDs
They detect an out of balance in current between ACTIVE & neutral
The only way that can occur is by a leakage to" earth" in an" 'earthed" neutral system.
or the very remote chance, that one or the other legs within the ELCB /RCD is bypassed
Perhaps you are referiing to the EARTH leakage detectors used by supply authorities that warned of line leakages???
PeterQ
Just had a handfull of popcorn
-- Edited by oldtrack123 on Thursday 2nd of April 2015 02:50:15 PM
Izabarack said
04:26 PM Apr 2, 2015
Phil C wrote:
Hi all
lets set this electrical hubbub straight.
1. 240 volts from our power points .....
I thought the standard supply in Aust was 230 volts? If we are going to get things straight, we need to start with the basics.
Iza
DeBe said
04:35 PM Apr 2, 2015
You will find a lot of places in Australia that consistenly have 250V AC these days. Where I live it was as high as 260V & I complained & they put in a recording volt meter to verify. They adjusted the feeder transformer taps & it now is contantly around 250v. You will be lucky to find a standard line voltage these days with all the solar grid supplies.
-- Edited by DeBe on Thursday 2nd of April 2015 04:43:00 PM
Izabarack wrote:
Phil C wrote:
Hi all
Iza
You've gotta love some folks sense of humour.
KFT said
07:42 PM Apr 2, 2015
This lot should keep you going for a while mate
just yell out if need more ok? This bloke is doing me a great deal because I am buying so much.
Hi all
but I will add this, please see below:
HI
PeterQ
Hi again,
Sure can Phil
My response
Pomme.
PeterQ
Iza
slightly off topic there Doug
but yes mate how many bags would you,like?
I can do you a special deal tonight only though
1 for B, 1 for B, 1 for Me, makes 3 please.
Sorry to go
Phil so back on topic mate, I think,
