Just found these on EBay Mini Ampfibian 10 AMP -15 AMP CARAVAN CONNECTOR. $68.00 a bit cheaper than there normal one at $200. Plus.
Lance C
brickies said
06:06 PM Apr 1, 2015
I think you will find there is a difference , I was at a Camec store and they had the 2 types the cheap one is for inside use only and are not water proof .
Phil C said
06:37 PM Apr 1, 2015
Be careful, not all eBay electrical items conform to Australian standards. Just a word of caution from an electrician.
Olley46 said
08:24 PM Apr 1, 2015
Very expensive water proofing.
Lance C
09:15 PM Apr 1, 2015
Lance C
I think it is not just because of "the waterproofing" but because of the extensive, rigorous evaluation and testing that is required to get the rating/approval to allow its 'unrestricted' use outdoors in all weathers.
cheers - John
madaboutled said
10:14 PM Apr 1, 2015
Just had a quick look on Fleabay, the cheap ones range in price from $65 to $95 + postage but they are all the indoor ones so they are not waterproof. You could get one of these from a caravan parts place for about the same price and save on the postage.
Again the more expensive ones on Fleabay for $200 plus are the waterproof ones, but again you could get one of these from a caravan parts place for about the same price and save on the postage.
ShortNorth said
12:45 AM Apr 2, 2015
Here is the KEY point -
All portable vehicles and their site supplies - that means your camper trailers, caravans and motorhomes MUST COMPLY with
AS/NZS 3001:2008/Amdt 1:2012 Electrical Installations Portable structures and vehicles including their site supplies
The Ampfibian RV-02MAX DOES COMPLY with AS/NZS 3001:2008/Amdt 1:2012
The Ampfibian MINI DOES NOT COMPLY with AS/NZS 3001:2008/Amdt 1:2012
The standards can't be any clearer than that - ignore at your own risk.
The MINI is designed only as a DIY adapter for power tools in an indoor environment - it is not approved for the connection of caravans and other RV's.
Brian - former Electrical Consulting Engineer - over 35 years in the electrical industry
Olley46 said
09:44 AM Apr 2, 2015
The Mini Ampfibian if not approved for caravans, would be bloody dangerous with power tools as well if not water proof.
Lance C
03_Troopy said
10:05 AM Apr 2, 2015
15A TO 10A POWER ADAPTER WITH RCD + OVERLOAD CONNECT 15A DEVICES TO STANDARD 10A POWERPOINTS SAFELY AND LEGALLY. FOR NON-COMMERCIAL (DIY) INDOOR USE.
KFT said
10:15 AM Apr 2, 2015
It would seem that the device mentioned by 03 Troopy has the same approvals as some other brands of outlet box that are approved for RV use in accordance with section 4.4 of AS/NZS 3001 and that approval is for indoor use only.
frank
-- Edited by KFT on Thursday 2nd of April 2015 10:17:42 AM
Olley46 said
10:45 AM Apr 2, 2015
Thanks KFT,03troopy you have just answered my query ,it is safe to use indoors for a caravan or what ever, thanks gents.
Lance C
Lance C
cheers - John
Lance C
Read the description from their website
Ampfibian Mini
frank
Lance C
