Would you believe there is NO drain **** on the 127L water tank to drain the tank water.
One of the stabilizer legs will not retract all the way in when winding up the leg.
Millard are promoting they have been making caravans for 70 years...........and they still can not make one correctly
fitzy said
01:07 AM Mar 16, 2015
Sounds more like a Coromal
landy said
11:00 PM Mar 16, 2015
Or a Traveller.
Possum3 said
11:07 PM Mar 16, 2015
New Avida same problem cannot drain tanks + another 64 major Faults on $80K van including major leaks in roof, second hand parts used in manufacture, Laminated panels cracked, etc.
Bruce and Bev said
09:28 AM Mar 17, 2015
sounds typical of the quality build and no quality control or pre=factory inspection of Australian built RV's. And they are so expensive!!!!!
We got up to 37 warranty faults with our Supreme which is now 7 months old and told by a major Perth caravan repairer (who doesn't sell any RVs) that Supreme is a better quality van.........unbelievable.
Ive just posted a problem with the taps of the water tanks - where a flying object has come off the road in transit and snapped it off.
fitzy said
10:56 AM Mar 20, 2015
Coromal are just as bad,shower won't drain(flat floor) side cladding loose etc.etc There are some shoddy
manufacturers out there and probably too many making vans. Who is checking on the quality as at around
$80k you would expect a better result surely.
How about a 3 year warranty to start with , maybe then they will have to improve or be forced out of the industry.
There seem to be far too many caravanners with too many annoying faults and the more communication we
assist each other with on sites like this I feel sure the manufacturers will eventually have to lift there game.
As an update...2 more issues have been found.
Or a Traveller.
Happy travelling all
