Has anyone had any experience:knowledge of these? It seems to tick all the boxes as multi purpose use. It even comes with a solar panel and air compressor. Do you think you could run a small TV off one? I found one on gumtree for $250 which seems quite reasonable. Thanks
Thanks Denis. I haven't bought one yet but the one I found also had a solar panel. Cheers
Jaahn said
10:09 PM Feb 21, 2015
Hi TropicalRose,
That unit will probably do what you want. Possibly more than you want with those other gadgets.The solar panels will be useful.
However note this information. It is basically just a small AGM battery in a box. The battery is small so is limited in its capacity. Probably about 20 amp hours capacity. You should only run it down to half capacity so it will do 10Ah. So if your tv uses 2amps them you will get 5 hrs out of it. Might just do it if you keep it charged up every day.
Give it a go and learn about the batteries and solar panels etc. If you find it is not enough then you might know enough then to get a better system. The more you run it down each time the faster it "wears out".
PS An AGM battery is an improved type of lead acid battery that is sealed and works better than the normal lead acid type.
hako said
11:31 PM Feb 21, 2015
That will be the one with the 20 watt solar panel - $310 new plus freight ($31) from the same site.
TropicalRose said
12:44 PM Feb 22, 2015
Denis That's the one but I found it for $250 new. Haven't contacted them yet though so we'll see.
Thanks for the info Jaahn. Luckily I probably couldn't watch that much TV at a time. I only have a hiace too do my needs aren't big. Cheers
-- Edited by TropicalRose on Sunday 22nd of February 2015 12:46:49 PM
They are available new for $182 from the link below....normally $310. Not sure if you've bought it yet.
http://www.wallcann.com.au/titan-6-in-1-multi-function-power-mate.html?gclid=CjwKEAiA9qCnBRCb7ZDhvaHSyicSJABGFFHtXEPqI5vviK6CCqGsvod_arKhlbROpuCApqLnWJCfuRoCgafw_wcB
Hi TropicalRose,
