We have a 5 year old waeco that will no longer work on 12 volt. It works very well on 240 but shows a red error light as soon as we switch it over. All the leads are good and 12 volt plug.
DeBe said
02:10 PM Feb 9, 2015
If you search there is a lot of info on Waeco fridges in this forum. Also what is the model number of your fridge?
KFT said
04:59 PM Feb 9, 2015
My waeco does that unless I turn it off before unplugging the powerpak and then turn it back on again all is ok
I usually get a low voltage alarm(red led flashing)
frank
terrytravellingman said
10:11 PM Feb 9, 2015
I have an old Engel and it won't work on 12 volt either the cost to repair was way too much. So what i did was i bought a 300 watt inverter and run it in the back of my car. Hope this helps if yours woRks out cost prohibitive to repair
frank
Cheers Terry
I had the same prob when mine at around 5 yrs check the fans, mine needed replacing and has worked fine ever since
Also check inside 12v plug may have a fuse
There is a good article by DeBe on the Waeco powersupply here:
http://thegreynomads.activeboard.com/t42448120/waeco-powersupply/
