Due to the high temperatures we are currently experiencing in SA I want to get a suitable 12 volt fan to use when free camping. I would be grateful for advice on models that really are efficient. I have looked at the oscillating type which can be fixed to either the wall or ceiling however they need to be wired into a 12 volt circuit. This presents some difficulty as I would need to connect it to a light circuit and all the light switch are at the front of the van and I wish to place the fan at the rear. This would mean I would have to switch the lights on to have the fan working, or alternativley replace a light (all LED downlight units) with a unit that has a separate switch and connect the fan to this. I would prefer a unit that could be plugged into the 12 volt cigarette type fitting if I can find one that is really efficient. I would be grateful for any advice/ help on this.
Thanks, David.
KFT said
10:37 AM Feb 8, 2015
Hi David,
We recently installed a caframo marine fan from whitworths marine. They are currently(till end March) on special for $60 off so $139 + post. these fans are quiet, have 3 speeds, very adjustable, selectable off timer and only draw 0.4 amp on high. They can be connected using the supplied wire or connected to a ciggy outlet if you have a lead.
Have 1 Siroco fan above the bed & about to fit another, I would recommend them.
Bravehearts said
05:20 PM Feb 8, 2015
Thanks to all who have responded, I really appreciate your comments.
David
Cruising Cruze said
06:58 PM Feb 8, 2015
For myself I use a computer 135mm fan still in it's powersuply housing moves a fair bit of air
Just anough for at night when going to sleep and bugger all noise
Cheers John
JayDee said
08:36 PM Feb 8, 2015
We installed one of these fans for last summer.
Very effective and I just used a ( junction joiners / T connection from Jaycar or whatever) from the light wiring above the bed. So I have a swithc for the fan and a switch for the overhead light. If I can install the fan any one can.
Works a treat for us.
Another vote for the Sirocco fans - got two about a year ago while living in my old caravan and ran them off a 240v/12v adapter. Very quiet, can be aimed 360 degrees in virtually any direction and has four pre-set timer settings. I'm just now working out where to mount them in the Hino. Bit pricey but well worth it.
Joe
gooba53 said
10:00 AM Feb 9, 2015
Thanks for this thread. We had a cheap fan from Jaycar it was so noisy, too noisy really. Looks like the sirocco is the way to go. They have a shop in Elizabeth Street , Melbourne . we'll go for a train trip (we like train rides) and listen to them and hopefully pick one or two up. Thanks for the info.
Cheers Dianne
Plain Truth said
07:36 PM Feb 10, 2015
We have a Sirocco fan they are great, but they do not oscillate, but they use very little power.
Thanks, David.
have a look here:www.whitworths.com.au/main_specials.asp
frank
Plus one for the Caframo, bit expensive but excellent little fan that draws very little current.
$135 posted
Pretty good price.
Have a look at USB fans may be an alternative
David
Cheers John
www.ebay.com.au/itm/12V-DC-Ceiling-Fan-12-Volt-WITH-SWITCH-for-caravan-very-low-wattage-/271131684169.
Note the price.
Jay&Dee
Joe
Cheers Dianne
