Just replaced all of the lights and fittings in our motorhome with LED's, 10 in all, great success.
This consisted of replacing 4 x 12 volt fluorescent fittings and 6 x quartz halogen bulbs, lighting level is remarkably better and power consumption reduced by approx 2/3rd's.
Total cost from Jaycar at Soldiers Point NSW about $200 and a few hours work on my part.
Cruising Cruze said
09:22 AM Dec 31, 2014
Which ones did you use to replace old ones Santa
maybe a part number is handy
Cheers John
Santa said
10:05 AM Dec 31, 2014
Did not keep part numbers John, all a bit of trial and error, each installation would be different, had to buy fittings that would cover existing screw holes etc.
The QH replacements were for two prong fittings, just a matter of plugging them in.
Pretty much a matter of visiting a store and selecting what meets your requirements, the people at Soldiers Point Jaycar were very helpful, I took the fluorescent fittings I wanted to replace with me and they powered them up aswell as the LED's allowing me to make a comparison.
Sorry I cant give a little more detail, there is so much available it's still a bit hit and miss, as it was I visited the store 4 times.
Muskat55 said
09:05 AM Jan 1, 2015
I have done likewise, incandescent globes were easy, but fluorescent a little more challenging especially if you want to retain the original fixture as we did. It was necessary to remove ballast and starters, I purchased T8 LED tubes and I am very happy with the result. I can recommend LEDS unlimited. http://www.ledsunlimited.com.au/
-- Edited by Muskat55 on Thursday 1st of January 2015 09:06:48 AM
-- Edited by Muskat55 on Thursday 1st of January 2015 09:08:12 AM
-- Edited by Muskat55 on Thursday 1st of January 2015 09:10:06 AM
Santa said
10:02 AM Jan 1, 2015
Morning Muskat,
I chose to replace the existing fluorescent fittings as diffusers etc were discoloured and tired looking, nice new fittings have given the interior a lift.
I understand that for economic reasons others may choose to retain the original fittings and, as you say, remove/replace existing components.
aussietraveller said
12:24 PM Jan 1, 2015
Recently replaced all of mine in the Jayco and it made a considerable difference I removed down light over the sink and purchased a led light bar with switch, the ceiling lights i replaced them with T10 24 led boards which I purchased on ebay item no 251263096884 at a cost of $6.99 each with free postage, they give heaps of white light and were cheaper than i could find in retail stores
Pangari said
11:11 AM Jan 3, 2015
Replaced halogen bulbs in the rangehood with LED. Was as simple as removing the old bulbs (2 pins), took it to a lighting shop and matched them to some LED bulbs. Plugged them in and presto. Now all LED in the RV.
Cruising Cruze said
10:39 AM Jan 4, 2015
@Aussietraveller
Please discard this message
Hi David
where did you get the whole light fitting from
I did try to find it on ebay but no luck so far
oops sorry I see that you've got an Jayco caravan
Cheers John
-- Edited by Cruising Cruze on Sunday 4th of January 2015 10:47:27 AM
Cheers John
Morning Muskat,
@Aussietraveller
Hi David
Cheers John
