I'm back. This time looking for advice on what to use to lubricate the zippers on my pop-top caravan. They are getting stiff to operate and am affraid that they might just stop working. Too expensive to replace, so need to fix.
Many thanks in advance. KB
04:29 PM Dec 5, 2014
I use this for such jobs -
But they also have it in aerosol now - not used it on zippers, but it is apparently quite effective.
I also use silicon spray on heaps of stuff (hinges/seatbelts/catches etc) that needs lubricating on the van and car.
jandas fun said
05:00 PM Dec 5, 2014
Yep. Silicon spray for mine as well. Use it on everything.
Johnw
Explorer said
05:05 PM Dec 5, 2014
Keiron,
I use Dry PTFE Lubricant put out by WD40.Works very well and will not stain (as usual check in a out of way place). Not cheap a 150g aerosol is about $20.00
Mike.
Nelly said
05:37 PM Dec 5, 2014
Soap or a wax candle can help.
dING said
06:27 PM Dec 5, 2014
Bees wax
Ozzie_Traveller said
08:09 PM Dec 5, 2014
G'day
Years ago when I was an active 'tenter', each year I used an old candle stub to rub into every zip on all our tents - and the stub is still at home somewhere even today. Cost - $0 as it was an old candle stub
Phil
Radar said
09:53 PM Dec 5, 2014
Hi All
From boy scouts and later on my wife was involved in Girl Guides we used lead pencil. Cheap everyone has one some where near them.
Yes good old lead pencil just rub the pencil along the undone zip, go on it will not take long. Ralph.
Dunmowin said
11:47 PM Dec 5, 2014
Mr D uses a stick of a yellow waxy sort of stuff, wipes it on zips, and also on sale track to lubricate. Seems to do the trick. I asked him what it was called - "I dunno" was reply. where would you buy it from "I dunno"
Does it work - I can reply to that, a resounding YES. Must be able to get it from camping shops - probably called "zipper lubricant" Sorry cant be of much more help.
meetoo said
03:22 AM Dec 6, 2014
Hi keiron, I use silicon spray on zips. Works well. Some silicon sprays are drier than others.
Cheers John
Cloak said
12:27 PM Dec 7, 2014
I'm with Nelly and run a candle along the zip.
Phil S said
02:42 PM Dec 7, 2014
The pencil works (it contains graphite, used by locksmiths to keep locks working) but can be a bit dirty.
Dri-lube is excellent, but a spray tends to get everywhere, so the stick is better, smaller, and cheaper, and my preferred choice.
In an emergency, or if you are really tight for space or money, the candle does almost as good a job, and is essentially free.
Regards, Phil S.
Igo said
11:02 AM Dec 8, 2014
I use the item above, bought at a country IGA on a shelf among WD40 and similar products. It is like a soft candle wax (which probably works just as well) and you just run the stick along the zips, it is excellent. One advantage is no spray going everywhere. Bunnings or other hardware or camping stores will probably stock it also.
Johnw
Keiron,
Mike.
Bees wax
Phil
Hi All
Cheers John
Regards, Phil S.
