I have gotten on with the job of getting 12 volt gear for the van.
So far - some agm batteries, solar panels, and inverter. Doing some head scratching on placement for it all.
Might go on to the tech section to check out some info.
05:44 AM Nov 29, 2014
How, meetoo,
All sounds good but make sure you use good size cable all through the system so you get full current all the way though. You want have any problems then. I'm sure you probably know that anyway.
I had to rewire the Avan Camper I had and used 6B&S all over then, I think for memory, 6mm to the 12v sockets and fridge. Worked a treat, for me.
Hope it all goes well for you.
