When free camping and you decide to turn in for the night...should I leave the gas hot water on or turn off. I'm guessing they operate like a domestic hws with a pilot light?
Thanks,
Collo.
Treecrest14 said
04:13 PM Nov 27, 2014
Personally, I turn it off and only on when we want hot water. It doesn't take long for the water to heat up.
SnowT said
06:13 PM Nov 27, 2014
Just my Think'n..
If you don't need Hot water overnight turn it Off...
As Collo said it only takes 10min of so to heat up..
Juergen
Old Crofter said
07:13 PM Nov 27, 2014
We turn ours off, as said takes only few mins to heat.
bob
Big Gorilla said
08:03 PM Nov 27, 2014
No point in burning gas if you don't need it !!
09:00 PM Nov 27, 2014
I have a continuous (Instant) hot water system fitted to the new Chief and not yet used it but I will be trying out the shower for the first rime in the morning. I just turn the 12v power switch on when I want hot water then turn it off again.
D and D said
10:23 PM Nov 27, 2014
We switch the gas off when not using it and use the electric heater when in a CP or similar and are paying for a powered site.
Dave
Phil C said
11:16 PM Nov 27, 2014
We switch it off as well. Save gas.
shekon said
05:14 PM Nov 28, 2014
Switch it off. I left it on by mistake one day and used up a full gas bottle. Completely forgot about it, was out sightseeing and had plenty of hot water but had to change the gas bottle. I also turn off the electricity once I have my water hot. Can't remember why, but I know when I purchased Miss Daisy, in the walk around and hand over it was something that I was told to do. So being a good little girl decided to do what I was told.
blaze said
10:06 PM Nov 28, 2014
seems I am the odd one out, I leave mine turned on
blaze
Diggings said
10:08 AM Nov 29, 2014
Definitely off because I can hear it starting and burning gas, and I am to tight to waste gas.
Delta18 said
10:47 AM Nov 29, 2014
I always turn our HWS off when not in use. As said, 10 - 15 minutes heating provides ample hot water for 2 of us to shower. It is turned off before the first shower.
I have seen some people either leave it on constantly and some will turn it on for 30 minutes to do the dishes! Why boil 20L of water to use 2L on dishes?
I use the kettle for dishes, heat as much water as required.
Cheers Neil
banjo said
12:41 PM Nov 29, 2014
As Delta18 above, why waste gas to wash the pots etc. we boil the jug ! for showering it takes around 15-20 mins enough for 2 showers easily.
We had someone next to us in a CP and their gas heater kept us awake all night firing up every hour or so, sounded like a jet engine ! god help the gas usage and cost.
The heaters only have minimal insulation so do not retain heat for that long, especially in cooler weather.
Just heat what you need when you need it.
Santa said
12:42 PM Nov 29, 2014
We turn ours off when not required Colo, a 4.5kg cylinder of gas will last us for 5 or 6 weeks using the stove only, leaving the HW service on empties it quick smart.
deverall11 said
07:57 PM Nov 29, 2014
Dave
If you turn on your hot water when you need it, you find you may save on the anode.
Larry
Blues Man said
10:11 AM Nov 30, 2014
Turn it off Collo,when you're not using the HWS .
We turn ours on only when we want hot water.(free camping)
If we stay in a CP, then the HWS is powered by electricity.
Bluesman.
MarkandDeb said
11:31 AM Nov 30, 2014
We turn ours on when we want to do the dishes after the first meal, it takes about 10-15mins to heat up from cold, after this we turn it off.
The next time we turn it on usually the night after or maybe lunch after it only takes about 5mins to heat up as our tank has superb insulation and keeps the water quite warm for a long period.
M&D
Dunmowin said
08:34 PM Nov 30, 2014
Turn it on 20m before your showers, turn it off after your shower.
Thanks,
Collo.
Juergen
bob
Dave
blaze
Cheers Neil
Larry
Bluesman.
M&D
