up until now I haven't used the waterheater in my dreamseeker sprinter campervan
when I did turn it on, the red light showed briefly then went out.
questions.
was there enough water stored and how can I tell?.
is there a separate tank for the hot water?
I filled up the tank before I left home 4 weeks ago and have used minimal amounts since as I've been in van parks and found it easier to fill a container than hitch up the hoses.
yes, i'm being lazy:)
I tried it on gas and electricity...which is the right one?
thanks in advance for advice and info
travel safely!
Peter_n_Margaret said
11:10 AM Nov 19, 2014
Without knowing what type/brand of heater you have, it is impossible to give advice.
Cheers, Peter
-- Edited by Peter_n_Margaret on Wednesday 19th of November 2014 11:10:46 AM
Sharke said
04:50 PM Nov 19, 2014
Sounds like you have a dual hot water with gas burner for bush camping and and electric when plugged into power.I have a suburban gas hot water and the red light comes on hen goes out once the burner ignites. cheers Jeff
-- Edited by Sharke on Wednesday 19th of November 2014 04:52:11 PM
Big Gorilla said
07:09 PM Nov 19, 2014
Mine is a gas unit with 12 volt igniter. When I turn on the igniter switch, the red light illuminates and goes out once the gas has fired up. I have noticed sometimes the red light might come on and go off two or three times before the gas ignites. I don't know the cause of that but overall I have no complaints.
TAJ said
07:18 PM Nov 19, 2014
should have a 240volt switch probably in a cupboard near
heater to use elect when in a caravan park
when first starts on gas my red light goes on and off
a few times sometimes starts first go
hope it helps TAJ
07:45 PM Nov 19, 2014
frednme wrote:was there enough water stored and how can I tell?.
You turn the hot water tap on and see if there is enough water.Are you getting water flow through the heater. If you fire the heater up without having water that has flowed through it you can bugger it. Have you been able to get water from the hot water tap.
The storage heaters in vans are just a cylindrical container with an electric element in them and a gas burner under. Water is supplied from the water tanks under the van or the high pressure hose connected to the water mains. The hot water is stored in the cylinder forming the bulk of the heater.
PeterInSa said
02:27 PM Nov 20, 2014
Fred re [up until now I haven't used the waterheater in my dreamseeker sprinter campervan]
If your heater is a suburban and you have not checked the Anode, suggest you pull it out and check. I check ours every 18 months or so. Make sure that power is disconnected from your campervan, would also turn off the gas. I Blue Tac any holes that could fill up with water after the anode is removed, and of course remove the Blue Tac after the Anode/new anode is replaced. ( A New Campervan less than 18 months should to me not require the anode to be checked.)
If the anode is not changed, regardless of whether you use the water heater or not, the lifespan of the heater will be greatly reduced. Have been told that Gas/electric anodes wear out quicker than Gas only, do not know how true this is.
05:24 PM Nov 20, 2014
Maybe looking at a video will assist. Ignore the bit about "bypass" and "winterising."
Ours shows red light till the gas ignites.. You can hear it..
Muskat55 said
02:01 PM Nov 23, 2014
Something interesting happened to me. I was told that the Suburban water heater in our Winnebago was "gas only" by the previous owner, and he was told the same by the original owner. Anyway I was mucking about the other day, pulled a drawer right out from under the oven and I could see the back of the water heater with a nice 240v cord coming out of it and plugged into a power outlet.......so I got out the manual for my "gas only" heater and there is a section not obvious or well written. It appears that on the outside of the unit in the bottom left hand side is a small almost hidden switch which was "off" ......I turned it to "on" and whammo! water heated by 240v mains power!! I suspect the first time in 8 years that this feature has been used. I also changed the anode which was down to about 15% left. Moral of the story its worth reading the manuals if you have them :)
aussie_paul said
02:04 PM Nov 23, 2014
hi,'
questions.
travel safely!
cheers Jeff
hope it helps TAJ
http://www.youtube.com/watch?v=Aw5cJMUrsaE
What a great find Michael...
A nice surprise...
