Hi guys. looking for a recommended solar installer -South east Victoria/ Morning peninsula or even Bellarine. Also thin flexible solar or flat panel mounted solar?
Wish there was a course on how to do these things!!!
Cheers Didi
Plendo said
03:13 PM Nov 16, 2014
Hi Didi,
I have not had any work done by Phil, or do I know anyone who has. But i have spoken to him a few times, he knows what he is talking about, and the prices he gave me for semi flexible solar panels were cheaper than I could import the same panels for.
Thanks Plendo. Ive seen the website but I thought they just supplied parts not installed them?
Brenda and Alan said
04:53 PM Nov 16, 2014
We also have semi flexible solar panels fitted and I coupled them up through a Votronic 420 Duo controller and use a Votronic 100s battery computer. Both sourced from Ebay but am very happy with them and they cost about the same as Plendos' recommendation
Alan
didi said
07:23 PM Nov 16, 2014
Thanks Alan- but Im looking for someone who can do it FOR me. Just not a techie. Need an installer. Cheers
SnowT said
07:58 PM Nov 16, 2014
Plendo you don't think there could be an issue with mounting them directly to the Roof..??
Juergen
09:29 PM Nov 16, 2014
I think the link from Plendo also fit as well as supply, try a phone call.
Alan
Plendo said
04:44 PM Nov 18, 2014
Given the choice I would insulate the semi flexible panels from the roof.
I have mine sitting on top of 10mm of insulation,with no air gaps. Now I have had some time to look at it, I would be tempted to get some light weight metal bent up to bracket the panels maybe 25mm off the roof, it would still be light, and would give the opportunity to dissipate heat rather than trap it in the panel as my config does.
I have talked this through with Phil at Solr 4 RV, and he sees the merit in the thinking as well.
exa41 said
06:37 PM Nov 18, 2014
When I did my install ,I just used 40mm square aluminium screwed to the roof and the panels mounted on them
Cheers Didi
Hi Didi,
https://solar4rvs.com.au/solar-panels-flexible.html
Phil Chapallaz B.Eng. C.Eng. MIET, MIEEE
Director
Solar 4 RVs
Mobile: 0488 918 910
Alan
Juergen
Alan
