We have a Starcraft 19.6 with rear ensuite. The folding divider has come adrift from the screws that run on the top runner. The only way I can see to fix it it to remove it first. However the fixed end has the screws concealed by the end of the divider. The divider is a one way push on to the bracket screwed to the wall. The attached diagram is my best reprentation of the problem. Has anyone had to remove a similar concertina divider and if so how?
Had a brainwave after posting about the divider. I threaded a length of 1.8 mm wire down fro the top and pulled down between the end of the divider and the bracket on the wall. Presto the divider came free.
