Earlier this year, I advised that Mr D was going to make a match stick model of a horse drawn tip tray that we saw in the historical village in Wagin, WA. Well, here it is, 2000 matches later, finally finished. He started it in Wagin in January this year, and finished it this week in Hatton Vale, Lockyer Valley, Queensland. We are hoping to donate it to the Gatton Transport Museum.
News today is that the Gatton Transport Museum want to the tip tray buggy to add to our collection there. Mr D is tickled pink.
Rob49 said
11:07 PM Nov 14, 2014
Amazing piece of work John, I wish I had the patience and the skill to be able to that.
Jonathan said
04:30 AM Nov 15, 2014
Very well done indeed .. !
Texas said
08:34 AM Nov 15, 2014
Agree with all the others - brilliant. Can you tell me how big/long/wide. Thanks
Dunmowin said
08:43 PM Nov 15, 2014
Thanks Jonathon,
Thanks Texas.
The buggy's dimensions are 350 mil long, 170 wide, 150 high, wheels outside diameter 130. Scale is 1:12. The cobb and co coach is also 1:12, can't measure in now cos it is in a museum.
Thanks Rob49
Patience comes with being on the road full time, sometimes you just have to stay put for a while, so this keeps Mr D's brain and fingers occupied. He has to work the whole thing out as there are no patterns or instructions. His men's shed consists of a board to glue the match sticks on, various small tools, i.e. dremel, pin drill, small hammer, aquadhere, very sharp knife, sand paper, soldering iron, oh, of course, matchsticks, and paint.
Pick a subject, photo graph and measure it, divide each measurement by 12 and start on one section, i.e. the draw bar, or the base of the cart, and just build on. Just copy the photos. Wheels (yes they are also made out of match sticks) are the biggest challenge (our secret for the time being) All the metal work is brass that can be soldered.
Simple exercise might be an out door dunny, or an old water tank. Not hard, just need to put it all together.
Next challenge might be a timber jinker, or a furphy, just have to find one to photograph.
Woody n Sue said
10:21 PM Nov 16, 2014
I am humbled in your presents absolutely amazing
Dunmowin said
02:53 PM Nov 17, 2014
Thanks Woody N Sue, some people can paint, some write, Mr D makes models out of match sticks! There is something in everyone, we just have to find it.
Just read another post by you, did not realise you make the little metal structures. Well done.
-- Edited by Dunmowin on Monday 17th of November 2014 05:00:31 PM
Dunmowin said
09:35 PM Nov 19, 2014
Took the tip tray buggy to the Gatton Transport Museum yesterday to add to our collection.
-- Edited by Dunmowin on Wednesday 19th of November 2014 09:59:12 PM
-- Edited by Dunmowin on Wednesday 19th of November 2014 10:07:37 PM
Bluesman, I see you are in Brisbane. Go out for a drive to Gatton Transport Museum, and see them in real life. Mr D thanks you for your kind words.
03_Troopy said
02:49 PM Dec 16, 2014
Fantastic models, that would take way more patience than I usually have. I have decided to give it a bit of a go though, but due to my poor eyesight I'm going modern and making mine from bic lighters instead.
Dunmowin said
09:33 PM Dec 16, 2014
Good luck with the bics troopy, but make sure you colour coordinate.
my van said
04:02 PM Mar 7, 2015
My latest effort with match sticks
Don't worry about dressing up my models yet
I have a lot to learn so more practice first.
Only been doing this for a few weeks.
Previous models
I need to try some wood filler , not sure where to get the right colour from
Working on a beach cottage now with the emphasis on the roof design.
This will try my patience
Dave
Thanks B&A, he put a lot into it. The hardest part was sourcing craft products as we travelled through remote areas of WA and NT.
Thanks D&D, will let you know how it goes - maybe we could arrange to meet half way!
The museum already have one of Mr D's models - a Cobb & Co Coach which also won grand champion at the Caboolture show a few years back (pic attached)
Hi Dunmowin
Nice work, detail is great, beaut picture.
Thank you. Ralph.
Hi Dunmowin
Nice work, great detail and photo. Ralph
Thanks Jonathon,
Thanks Texas.
Thanks Rob49
I am absolutely blown away with your models.
You are a real artisan .Well done .
Bluesman.
Paul, Mr D found a good primer that fills the "gaps" when he is working on his models (after he has sanded the bits)
Mr D
Yes I do need a wood filler ...what is a good type ?
I need a colouring dye . May be food dye in the (white) wood filler
I am very appreciative of some help .
I am keen to know about the dremel and what it is used for with the matchsticks ?
I have a dremel that has a few small drill bits and little grinding disks in the kit
but I was thinking of getting some sort of a cutter , cutting sticks one stick at a time is a bit much,
the other option is a wide wood chisel to chop a few sticks at a time.
There is so much to learn when it comes to stick modeling.
Cheers from Paul
Am I doing it Right. ?
stick bending. !
the 90 mm pipe is as far as I can bend the sticks
i would like to go smaller .
rolling the sticks a little flat helps to get a better bbending
It will be a long te before I get to fashion a wagon wheel. .
Bender
ma piece of scrap pipe and s rap timber , some twine , and two clomps just to get max bend on pipe
-- Edited by my van on Monday 9th of March 2015 06:52:33 PM
Seems to work
The match sticks dont like to bend too far
Soaking the sticks for two days or more.
Learning how is time consuming
A couple of bits of small timber , saw cuts to stick matches in
then bend with second bit of timber
this timber has saw cuts which I did not use ( practice cuts)
A good wood filler ....PREP 4 in 1....From Bunnings.
Why do you need food dye?.. are you going to eat it?...its timber. treat it like wood...treat the model the same as the full size original.
The Dremel is for drilling and shaping...I wish I had genuine one....I do all my shaping by hand.
Cutting the sticks....I think we are making models in different ways.....you make models.....I make Model Replicas...
So...I measure the item to be copied, divide each piece by 12. This gives me the size of my finished object.
For instance, I am making a timber jinker. The centre pole is 5.7 meters long...150 x 100 ml thick
Next I divide all those measurements by 12...so I make a pole 475 ml long ....12.5 x 8.3ml thick.
I do this by gluing many sticks together...with wood glue...clamp them tight, leave to dry...
when dry ....I can cut to length with a small hack saw...I use a junior hack saw.
then sand the pole smooth...until it looks like a piece of wood...not a lot of matchsticks glued together..
next...wood filler....then paint...
that is one piece of the jinker made.
now go on to the next piece...
I have like a production line going....when one piece has the glue drying. I can sand another piece.. or paint another. or measure another. and so on
when all pieces are made, I start assembling the jinker, just like the real thing, only 1 in 12 scale.
it is very interesting. just choose a subject that is simple to start with.. an old fashioned timber wheel barrow would be good.
