Is there any of our members with a older Ford Ranger PJ or PK that has removed
the air reflector inside the airfilter box, the one what is pop rivet to the outer skin of the airbox
If so did it made a difference in performance and fuel consumption ???
Regards John
scooner said
08:36 AM Nov 6, 2014
i have a pk and would also like more info on this if available ,reason why would they fit this if not required ??
Cruising Cruze said
11:58 AM Nov 6, 2014
Hi Ian
I just put it in a Ford Ranger forum
I will let you know what outcome is from it
did you ever cleaned your MAP (manifold absoloute pressure) and MAF (mass air flow) sensors your self ??
Cheers John
scooner said
06:11 PM Nov 6, 2014
No john I have a mechanic who does my servicing ,but if it's easy to get at I quite capable of cleaning it
We are on the road at the moment in Sydney so limited tools available regards ian
mr glassies said
05:09 PM Nov 9, 2014
if you do the sensor make sure you use the yellow top can theres a difference for petrol a diesel
Regards John
Hi Ian
Cheers John
dibs
