we are getting a diesel heater installed , originally it was going to be a webasto but now it is , is there any difference in them
peter1 said
06:27 PM Oct 31, 2014
We bought a Webasto at a trade show several years ago. I decided to have a go at fitting it myself (pen pusher by trade). The hardest part was drilling the first hole in the floor, once started all was good. The Webasto has been good - a little noise when starting up - otherwise excellent and uses very little diesel fuel. Dometic may also be good but we opted for the Webasto.
Dunmowin said
06:31 PM Oct 31, 2014
Our Kedron came with Webasto - would not have survived winters without it.
elliemike said
09:41 AM Nov 1, 2014
We have a Dometic. Always been pleased with it. Uses very little diesel per hour of running. Just this month though it has started smoking on start up. OK when running though. Anyone recommend a sercice agent in Perth.
elliemike said
09:43 AM Nov 1, 2014
Not sure why this has duplicated and now I cant delete it!
-- Edited by elliemike on Saturday 1st of November 2014 09:46:31 AM
Blue said
03:38 PM Nov 1, 2014
any European Diesel heater should be fine.. they have been making them forever..
Blue said
03:41 PM Nov 1, 2014
how much are you being quoted ?
Dunmowin said
03:48 PM Nov 1, 2014
Good Dometic agent in Manjimup. When we were based at William Bay, near Denmark, they arranged for a freight co to collect it from us, took it to town, serviced then returned to us. Check out Dometic listings for their agents.
NOTE: diesel heaters need to be serviced regularly.
Blue said
04:07 PM Nov 1, 2014
Dunmowin wrote:
Generally no! Webasto heaters are maintenance-free and do not have to be inspected every two years. We only recommend operating the heater every two months for 10-15min.
-- Edited by Blue on Saturday 1st of November 2014 04:08:23 PM
Brenda and Alan said
04:24 PM Nov 1, 2014
We took ours to Dometic at 12 Prosperity Avenue, Wangara 08 9303 3555. Did a good job and cheap.
Blue said
06:18 PM Nov 1, 2014
ok, I checked ours and its a Webasto 2000 ST
it goes like a rippa and hardly uses any fuel..
flat out its rated at 240 mil an hour... so if it ran flat out for 4 hours it would only use ONE litre of fuel..
but after they warm up the van they turn back the heat automatically down to idle and then off... if it gets cold again, they turn themselves back on...
the pulse pump makes a knocking noise but if its mounted properly on the rubbers they are not too bad...
good luck!
elliemike said
12:52 AM Nov 2, 2014
Thanks for that. I have to go up that way to visit rellies on a regular basis.
We live in South Perth, so I will check up if there is anyone down this way first.
Just arrived home after two months on the road.
Mike
04:26 PM Nov 2, 2014
This is a bit of a Holden/Falcon discussion. Do your homework and select the best deal. The best deal may be the one where you are assured of the best service rather than the best price. I was in bit of a hurry to get mine fitted so the dealer that could supply first won the day. Webasto won but I was initially looking at the Dometic one.
mr glassies said
06:02 PM Nov 2, 2014
i have one of these its gr8 m8 woof .and a gr8 company to deal with i buy heaps of them even stuff for my business
Gidday Dibs, had a look at your link, ? Heater looks and sounds good, Much trouble to install ?? and does it come with full instructions ?/ The company seems to have a very good reputation, as far as quality and service, go. Price looks good compared to both Dometic and Webasto, who seem to control the RV market, and make you pay big $$$ For supply and for Installation .
regards Dazren, [
mr glassies said
08:10 AM Nov 3, 2014
yep dazren
i found it the cheapest one around there mostly all the same or work in the same way so i thought why pay 3 times more for a big brand one when i could get this one . was easy to install good instructions and works gr8 . little bit of fan noise in side but all fans and fan heaters air conditioners make a noise don't they . out side is a bit noisier and there is a bit of black smoke and diesel smell on start up but it goes away when running . same again without the smell for a air conditioner . fitting instructions were good and running instructions were good . biggest problem i found was priming the pump first up. .
and like i said there a good company to deal with i have been a customer of theres for about 5 yrs never had a problem . i bought a remote fro the hester and part of it was missing .1 phone call and 2 days later it arrived .
recommend this shop and this product
dibs
mr glassies said
05:48 PM Nov 9, 2014
lol at servicing yep had it serviced they started it changed the filter um what next o yea charge you
dibs
-- Edited by mr glassies on Sunday 9th of November 2014 05:49:14 PM
this is what is says on the webasto site...
Do Webasto heaters need to be serviced? Is a regular technical inspection needed?
http://www.webasto.com/int/markets-products/recreational-vehicles/heating-solutions/service-downloads/faq-heating-general/
good luck!
Mike
www.ebay.com.au/itm/12v-PLANAR-2KW-DIESEL-AIR-HEATER-CARAVAN-MOTORHOME-DIESEL-TANK-/330992879231
dibs
regards Dazren, [
dibs
dibs
