I have a Redarc BC-DC 1220 , under the bonnet of my Hilux , charging the aux deep cycle batt , just driven home about 3 1/2 hours . multimeter shows only 12.36 vlots , i will talk to a autolec tomorrow but dose anyone if BC-DC things are throw away items or a adjustable / fixable item
RedArc is a great South Australian company and their tech service and back up is second to none.
If you are in Adelaide, you can also call in and talk to them face to face.
JackoFJR said
12:16 PM Oct 20, 2014
Looks like it's only a crappy fuse connection , I will replace it and tidy up a bit of wiring and all should be good again
Also you can ring and talk to a tech . They are very helpfull .
I see Jack has fixed the problem . That is one thing you must have is good connections
JackoFJR said
06:43 PM Oct 22, 2014
Yep it is all good again now . Turns out I was already a member of the Redarc forum , I had just forgot all about it .
09:26 AM Oct 24, 2014
Great out come.. At times I feel you are looked at like you've got money so let's charge !!
KFT said
09:04 PM Oct 24, 2014
As I understand it Redarc do not recommend installation under the bonnet because it gets too hot in there.
JackoFJR said
09:58 PM Oct 24, 2014
I talked to Redarc tech department before I installed it about 4 years ago the bloke I talked to had one under the bonnet of his own Prado
There is a thread on the Redarc forum now about installing one under the bonnet of a Prado .
KFT said
10:25 AM Oct 25, 2014
Thanks Jacko
not sure where I read it now but you seem to have done the research
hope it all works ok for you
frank
03_troopy said
11:49 AM Oct 26, 2014
KFT, was it possible that they were recommending not to fit AGM bateries under the bonnet and not the charger itself?
KFT said
01:33 PM Oct 26, 2014
G'day 03 troopy
It was a while ago so you could be on the mark there.
Next time I am researching those things I will see if I can find it.
regards Jacko
Redarc have a forum where you can ask their factory tech questions. Sign up here and log in
Great thanks
frank
frank
