Where to store your hitch bars without getting grease over things.
Happy Camper said
12:40 PM Sep 26, 2014
I've always had a problem of where to store the hitch bars without the ends getting grease over things when I get to the site.
By reversing the bars the other way and hanging them just under the A frame on a sling solved the problem.
If I'm in a area that could be a bit suspect I run the high tensile wire through the chains that I use to lock up my sat dish & solar panels.
A good cheap fix that didn't require drilling holes that worked for me.
Cheers, - John
01:46 PM Sep 26, 2014
Very good idea John. Always good to see tips like that. Thanks for shareing and the pic.
grahamg said
07:18 PM Sep 26, 2014
like you idea for storing the rubber mats as well
Hodgey said
11:45 AM Oct 17, 2014
We use a pair of woolen socks, stretch open and place each over the greasy end and store where you like.
03_troopy said
07:19 PM Oct 18, 2014
I use old work socks for storing ratchet straps. You can usually fit a pair of ratchet straps in each sock, and it stops them getting all tangled. Looks funny with my workboots and no socks though.
Phil C said
07:32 PM Oct 28, 2014
Thanks John, great idea
aussietraveller said
09:37 PM Nov 26, 2014
On our Jayco there is a box channel across the front of the van and I slide them in chain end first, out of the way and out of sight
JayDee said
12:04 PM Feb 7, 2015
Thanks Happy Camper... John.
I will do exactly the same with the sock cover added.
Jay&Dee
Cheers, - John
Jay&Dee
