can someone please point me in the right direction of where to plug in the scangaige 2 to an LC200 series GXL Landcruiser..
Appreciated
Trevor law said
06:13 PM Sep 19, 2014
If you lower the steering wheel down . Then your hand up under the dash near the steering column you should find the plug there . Just run the scan gauge wire down the gap .then plug it in hopes this helps
Papou said
07:08 PM Sep 19, 2014
Many thanks and kindly appreciated
Papou said
07:11 PM Sep 19, 2014
PS, easy to see and fit??
Trevor law said
06:58 AM Sep 20, 2014
All you do is plug it in and follow the instructions .it is a fiddler at first but is amazing what it will do .I got mine just to see fuel per 100 K's water temp and auto trans temp .you will be surprised at the auto trans temp .hope it is helpful
Appreciated
