I've bought a 1982 Coaster from someone who was here in the Park. Can't find where the battery is supposed to live. I was told it's under the step of the side door, but no sign of anything there. It's a 4 cyl Diesel, 2B engine. All kitted out with cooking and sleeping facilities, but don't think it has run for a year or two. Any advice will be much appreciated.
Bill
yeoeleven said
05:42 PM Sep 7, 2014
Glenhuon wrote:
Hi guys,
Bill
In my 1980 Coaster the cranking battery is located between the front wheel arch and the side door. John
Blue said
05:47 PM Sep 7, 2014
usually there's a small door in the floor... perhaps near the side door
should be located on the outside of the chassis rails so stick your head underneath and take a gander...
Murraman said
05:49 PM Sep 7, 2014
Our 85 Coaster was in the same position as yeoeleven but it is now located under bed on passenger side just past the door. If you look under the bus you can trace the cables from starter motor to Batt/s. You may have house batteries as well. Ours has 3 batteries in the one location.
Good luck with your adventure
Allan
exa41 said
06:57 PM Sep 7, 2014
Yep , I have a 83 coaster and the cranking battery is just in front of the side door, never know it could have been moved.
SnowT said
06:59 PM Sep 7, 2014
In the 93 + coaster the Batteries are located on the Right side of the Door when you look at it from the outside..
For John going from his description the Battery is Located on the Left hand side..
-- Look for a Lift up hatch in the Floor...
Hi guys,
Bill
Allan
hope this helps..
Juergen
