Help needed , What is correct temp.to set for freezing in 35lit.as doesn't seem to be freezing ,going away tomorrow. thanks
oldbobsbus said
05:19 PM Sep 5, 2014
Why dont you just set it to the coldest and work from there..
KFT said
05:47 PM Sep 5, 2014
Hi Noelene, most freezers store at a temp of -18 deg C
If your stuff is already frozen when you place it in thefreezer you can keep it frozen at -10 deg C
hope that helps
frank
-- Edited by KFT on Friday 5th of September 2014 05:48:01 PM
Noelene said
06:24 PM Sep 5, 2014
thanks all seem I didn't have it set cold enough
hako said
06:34 PM Sep 5, 2014
They can take quite some time to pull the temperature down - if you fill the freezer with food at room temperature and set the temp at -20 it can take 48 hours to go that low.
hope that helps
frank
commercial freezers run way below minus 20 C
Cheers John
