I have read that having the regulator that far away from battery is not the best. Can I remove the supplied regulator and feed into the 15 amp regulator that the rooftop solar panel feeds into?
oldtrack123 said
11:42 AM Aug 27, 2014
HI Paul
That will depend on the panel sizes you have on the roof.
If They exceed 120W the answer is NO
PeterQ
aussie_paul said
11:49 AM Aug 27, 2014
oldtrack123 wrote:
HI Paul
PeterQ
The roof panel is 120 w Peter.
oldtrack123 said
12:02 PM Aug 27, 2014
aussie_paul wrote:
oldtrack123 wrote:
HI Paul
PeterQ
HI Paul
Iin that case, yes.
Remove or bypass the reg on the portable panel & feed into the VAN rgulator[ in parallel with the existing panel]
Me again.
Needing more help. I bought this a couple of months ago,
http://www.ebay.com.au/itm/161340795730?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
HI Paul
PeterQ
HI Paul
Iin that case, yes.
PeterQ
