How many amps a 600 watts pure sine wave inverter drawn from a 12 v battery ? Regards GG thank you
Plendo said
08:04 PM Aug 26, 2014
Hi Gerard, the amount of current drawn by an inverter is governed by the load being imposed on it by the 240V device it is powering, thus if we say it is running flat out it will provide just over 2 amps at 240V, and in the process will draw 600W from the battery, this will take 50Amps, plus a bit to make up for the inefficiency of the inverter, so say an extra 10%.
Maximum current draw about 55 amps.
bill12 said
08:05 PM Aug 26, 2014
600 watts divided by 12v (nominal) is 50 amps. This will varie as to load and condition of battery. Bill
-- Edited by bill12 on Tuesday 26th of August 2014 08:18:03 PM
SnowT said
08:18 PM Aug 26, 2014
bill12 wrote:
600 watts divided by 12v (nominal) is 30 amps. This will varie as to load and condition of battery. Bill
Bill did you work that out on your finger's....
30
12 x
360 =
sorry had to Bill...
Juergen
12:28 AM Aug 27, 2014
The rule of thumb when working with inverters is to divide the load drawn by 10 and not 12. This takes into both the power loss in the inverter and also the smaller losses in the cabling (never discount the second loss, the inverter has also got to make up for the loss there.)
A 600 W inverter could draw 60 A running flat chat.
-- Edited by PeterD on Wednesday 27th of August 2014 12:29:09 AM
bill12 said
02:34 AM Aug 27, 2014
If you would read the post, I changed it 10 mins later.
The Hats said
11:24 AM Aug 27, 2014
G/Day mate on stand by they draw about .5-.7 Amps so they can be a drain if you are not charging your batteries Make sure you have a good heavy wire connecting the inverter to the battery. Here is a link to a very good table and info that will help you will see at 40 amps with a 2 mtr cable you need a cable that has a cross section of 8mm This is the cable I use and I solder all jions and use an Anderson plug for any connections. www.rpc.com.au/pdf/Wire_Chart.pdf Cheers The Hats
-- Edited by The Hats on Wednesday 27th of August 2014 03:56:02 PM
-- Edited by The Hats on Wednesday 27th of August 2014 03:56:36 PM
oldtrack123 said
11:57 AM Aug 27, 2014
The Hats wrote:
G/Day mate on stand by they draw about 5-7 Amps so they can be a drain if you are not charging your batteries
Cheers The Hats
I would be throwing THAT ONE away
12% of rated ouput in standby
PeterQ
SnowT said
01:03 PM Aug 27, 2014
I have a 2400w inverter that draws about .5A's on standby and a lot less than that if I put it in power save mode..
Can't use Power save mode as it will not switch on, when the fridge kicks in...
Juergen
oldtrack123 said
02:12 PM Aug 27, 2014
Juergen
Hi Jurgen
A typo??
I suspect the poster did mean 0.5<0.7A
PeterQ
Phil C said
02:19 PM Aug 27, 2014
Hi Jurgen
A typo??
I suspect the poster did mean 0.5<0.7Abiggrin
PeterQ
Yeah I agree PeterQ
My inverter is allegedly 2500W and draws 900mA on standby. so 500mA to 700mA sounds about correct.
The Hats said
03:55 PM Aug 27, 2014
oldtrack123 wrote:
Cheers The Hats
PeterQ
Guess which idiot did,t put in the decimal point
The Hats
oldtrack123 said
09:09 PM Aug 27, 2014
The Hats
HI Hats
I did use mymagnify glass in case the was a small Dec point
But you could have just said it was a typo
I have plenty of them
I like to put at least an 0 in front of the dec point [0.7A]
30
12 x
360 =
Juergen
The Hats
PeterQ
Juergen
Hi Jurgen
A typo??
PeterQ
A typo??
PeterQ
Yeah I agree PeterQ
The Hats
HI Hats
PeterQ
