anyone have an idea how long a 9kg gas bottle will run a caravan fridge ?
Cruising Cruze said
11:49 PM Aug 23, 2014
just a bit more than 14 days but that's including boiling water for tea & coffee from 9kg
Cheers John
glennt said
11:54 PM Aug 23, 2014
Very helpful thanks John...
sarg said
09:49 AM Aug 24, 2014
Hi Glen, I've been told it should last for about 3 weeks if used on fridge alone.
and .... I'm camping full time now so will let you know when my gas runs out, as I have just put a full bottle on last Monday 18th. Cheers sarg
Roving-Dutchy said
09:52 AM Aug 24, 2014
It will vary according to the temperature the hotter the weather the more gas you will use and also the size of the fridge will determine the gas use.
David
09:59 AM Aug 24, 2014
As all the above said - several variants - we have a 3 way fridge, and use the gas cooker a fair bit, our hot water also uses gas, but we only turn that on when we need it. We have had 9kg bottle last from 15 days to 25 days - weather dependent, cooking dependent, etc. In the motorhome we have a 9kg and a 4.5kg in the gas compartment, so swap over when needed - which is quite often in the middle of the night!!!!!! Very happy is Billeeeeeee when he has to get out and change over at that time!
Brenda and Alan said
10:38 AM Aug 24, 2014
Hi Glen
We get about 3 weeks per bottle running fridge, hot water (first thing in the morning only) and cooking (cakes, casseroles, apple crumble, etc. as well as lots of cuppas)
deverall11 said
12:10 PM Aug 24, 2014
Glen, a 190 lt ometic is rated at 460g/h. or 3.9KWh
glennt said
01:23 PM Aug 24, 2014
Thanks. Everyone great info. Have something solid to go with now. Great help to me ....
Blue said
07:50 PM Aug 25, 2014
it also pays to know if you have a subtropical fridge or a FULL Tropical fridge..
Cheers John
David
always make sure you get the full Tropical ...
