Hi everyone we have a bus which seem to keep letting water in along the windows
have rescaled some and it did rain for weeks without a leak ya all fixed I thought
but no after 2months more leaks.
now I'm thinking of maybe fitting some sort of guttering / moulding to the roof to stop the
water running down the windows . Has anyone got any ideas please
Olley46 said
09:39 PM Jun 21, 2014
Hi Lomes
I had a similar problem with 3van windows,what I did was fitted a Aluminium gutter flush with the top of the window frame,the Aluminium gutter has been cut about 100 mm wider than the window frame,I have fitted the Aluminium gutter with double sided tape from Repco the same width as the guttering that's 100mm each side of the window frame ,since I have fitted the gutters we have had some heavy rain guess what no leaks seems they have done the job,I had trouble with the front boot leaking as well, what I did with it was fitted the Aluminium gutter at the bottom of the boot lid but upside down,what I think was the problem there was while driving the wind was forcing the water up under the bottom of the lid,this experiment has not been tried as yet,plus a new boot rubber fitted to the inner edge,see what happens in about 6weeks.
ps I got this idea off another vanner I asked about the heat with the double sided tape, he said not a problem in 40 degree plus heat, a plus not having to drill holes.
Lance C
-- Edited by Olley46 on Saturday 21st of June 2014 09:45:11 PM
Lomes said
10:31 PM Jun 21, 2014
Ok thanks for the idea could you put up a photo when you get chance
Cheers Lomes
Legendts said
09:36 AM Jun 22, 2014
Capt (Mr?)Tolleys has been suggested as an excellent leak fixer.
Olley46 said
04:48 PM Jun 22, 2014
Hi Lomes
Lance C
Cheers Lomes
Here is a couple of pics
And one more
Just wondering if you fitted the gutters and what the end result was. Thinking about putting them on the m/home to stop a window leak.
