I realize that this is a controversial subject & I watched with interest a TV session on 4WD Pro Tips last night.
A representative from 360 Gearbox & Diffs (I think that was their business name) stated quite emphatically that you should not tow in 5th gear & went on to describe why.
She also described the way that they strengthen gear boxes & stressed that they recommend that even the strengthened boxes should not be used for 5th gear towing.
Very interesting to me was a (lay?) shaft from an early Nissan patrol that showed the small width gear that is often damaged by towing in 5th. They modified it to be about twice as wide. A mechanic at Darwin showed me the same thing when he was fixing a noisy thrust bearing in my 1996 4.2 EFI Patrol.
When I got the Nissan in 1998 my mechanic stressed that I should not tow in 5th & I have always followed this advice. A call to the then Nissan Qld Service Manager confirmed this view.
Have towed a 2.5 ton van for >200,000km with no problems so far.
Jaahn said
09:42 AM Jun 20, 2014
Hi Cupie,
If it ain't broke don't fix it. Keep using 4th for another couple of hundreds of kms 4th gear in these boxes is a direct through drive so there are no gears being used to wear or break. Makes sense
jaahn
-- Edited by Jaahn on Friday 20th of June 2014 09:43:56 AM
deverall11 said
10:59 AM Jun 20, 2014
We get the same fuel consumption towing in 4th then in 5th. Why would you tow in 5th.
Larry
11:01 AM Jun 20, 2014
Exactly in most cases top gear is over drive..
In turbo diesels it puts unwanted stress on whole drive train..
sandsmere said
01:09 PM Jun 20, 2014
Agree with all the above.
Anyone that really knows anything about towing a van will tell you. . . . . ." Don't tow in fifth ".
Legendts said
06:10 PM Jun 20, 2014
It does depend on the car, and gearbox type, I'm particularly referring to the newer 6, 7 & 8 speed auto boxes. Generally, if it's a 5 speed box the fifth gear is an overdrive and you would always tow in fourth if you wanted to go easy on it and make it last longer.
Collo said
06:50 PM Jun 20, 2014
We have bought a 2010 2.5l Diesel Tritron 5 speed auto. 17.5 foot van.
Asked Mitsuibishi dealership about towing and their response was that they have never seen any problems with towing in their autos.
The vehicle manual has no warnings re towing.
Van travels at 90/100 kms comfortably.
justcruisin01 said
07:52 PM Jun 20, 2014
The old Troopy that I have been using for the last 25 yrs for towing had 350.000kls on the clock. Ive done 275 of them , 200 would be townig a 1.5ton off rd camper trailer with boat etc, also caravan for many of them.
It is anold 4lt that I turbo'ed to make some thing of a vehicle of it, Its been around the block, criss crossed the country, cape york twice, simpson, tanami, corner country, birdsville track, gibb river twice etc etc, always used 5th with no problems.
In saying that its an old heavy duty system & has had a hard life.
As for the newer units then I have to agree with what has been said, they are much lighter built with a small 5th gear outside the main box in the extension housing with very little support for the bearings as well.
I may add that the new Iveco just loves 6th, pulls hard with no effort.
JC.
The Phantom said
11:19 PM Jun 20, 2014
I tow in 5th. Never had a problem with it.
The Mazda has a 6 speed box
The Phantom
Kendo said
11:18 AM Jun 21, 2014
My 2013 has the 4 speed auto. I'd also be interested in any information
Phil C said
12:16 PM Jun 21, 2014
I have a Ford XL 2012 ranger ute, 6 speed box. I was told never to tow in 6th (overdrive) as it puts too much stress on the drive train. OK this confirms it, 5th gear while towing. Thanks guys
Safe travels
Cupie said
04:34 PM Jun 21, 2014
The Phantom
Hi. P
I aught to have qualified my initial comment to specify that I was referring to 5th or overdrive in a 5 speed manual box.
Cupie said
04:36 PM Jun 21, 2014
justcruisin01 wrote:
snip ...
JC.
Spot on & that lack of bearing support & small 5th gear, seems to be at the crux of the problem.
-- Edited by Cupie on Saturday 21st of June 2014 10:19:09 PM
BTSV_Berni said
09:33 PM Jun 21, 2014
Just blown up my auto transmission because I had no idea that this thing has an overdrive which is always on. Has to be turned off for towing. It was gone in no time. ! After that I did a bit of further investigation and found out that towing in highest gear (manual) or overdrive (auto trans) can kill your gear box in no time. "Can". Ordered a transmission temperature gauge and will put it in next week. The temperature of the ATF is a very good indicator to see if everything is going well or not. Can save thousands of dollars.
Be aware that, if it worked for you a couple of times and you didn't have any problems, does not mean that it is the way to go. Can be a very costly experience. I didn't have any problems until it was too late...........and my vehicle manual has no warning too.
Regards, Berni
-- Edited by BTSV_Berni on Saturday 21st of June 2014 09:36:30 PM
Collo said
09:41 PM Jun 21, 2014
Bernie,
What make/model and year?
Olley46 said
10:20 PM Jun 21, 2014
I bought a s/h Prado about 8 years ago 4 speed Auto ,I asked the salesman at Toyota what gear to tow in his answer was put it in Drive and let it do it's own thing 2000 model that was 1.5 around the block not a problem ,have a 03 diesel Prado 4 speed now and do the same no problems yet touch wood.
Lance C
BTSV_Berni said
10:25 PM Jun 21, 2014
Mazda Tribute 2006. Google for it and you'll find heaps of transmission fails. Read far further (and between the lines) and you'll find out that most of the problems were selfmade due to lack of knowledge and lack of information from the manufacturer (manual). Ford CD4E Transmission. Needs regular transmission service (every 30k) and shorter transmission service intervals (15-20k) if used for towing.
If treated right it lasts forever, if treated wrong.......500km. . If you have your service done by a dodgy workshop that only ticks the box.......you are f...d. And it is impossible
to get some evidence for the not done right service.
This transmission is also in the Ford Escape and the older Mazda 626......and a few other cars.
I didn't even know that it has an overdrive and didn't know that it "can" be turned off. RTFM. . But even that wouldn't help because the manual doesn't tell me to turn it off
when towing. A fail in the manual made by the manufacturer.
Keeping an eye on the ATF temperature seems to be essential for all auto transmissions. No matter what make. An unusual increase of temperature is a good indicator that something
in the trans is going wrong and if detected early enough it is relatively inexpensive to fix. If the warning light in the dash board comes on then the trans is gone.
I've learned it the hard way.
Regards, Berni
Baz421 said
10:35 PM Jun 21, 2014
What were you towing Bernie and weight,, and is it 4 or 6 cyl???
sorry to hear of your dilema
-- Edited by Baz421 on Saturday 21st of June 2014 10:37:58 PM
BTSV_Berni said
10:51 PM Jun 21, 2014
No big drama. Towing my A'van Aliner. Every 4-6 weeks for about 35 km. Not that much, but enough to kill it. .
I'm already used to the good old stuff. Had a Mercedes 280 E W123, taken over from my father at 200k and sold it for 50 Dollar years later with 800k on the odo. Never done any kind of service.
After that I bought a 300 E W124 with 180k on the odo. Did a service when I bought it and after that refilled the oil level when needed. Next service happened at 500k......the oil filter was gone completely (only the rubber rings were left) . And this thing was a rocket. 240km/h on the good german autobahn nearly every second weekend fully loaded with mates for going to away matches from my soccer club. Was built to last for ever.
With the Mazda all services were done..........didn't help that much, and no one knows if it was really done or if only a few boxes were ticked.
Nowadays all cars/parts are designed to the limit from the beginning. Old VW Golf with 1.3 litre engine had 60 hp. now they get 160 hp out of the same size engine. That can not last long without service. And even with service it will never last as long as the old bricks did.
Regards, Berni
12:51 AM Jun 22, 2014
In newer turbo diesels .. Towing in high gears for long periods heats up turbo exhaust housing . As it works its gut out trying to maintain speed.. It's ok for short periods. But say ? Cruising around 89 /90 kph in a 4 cyl (ESP) is hard work . Even though it sounds ok diving .. The bigger Diesel engines don't have the same issue..
Hi Cupie,
jaahn
Larry
JC.
The Phantom
Safe travels
Hi. P
"Can".
Regards, Berni
Bernie,
Lance C
Regards, Berni
Regards, Berni
