Occasionally whilst i am towing my pop top on concrete roads the Colorado feels like i am driving over ripple strips,this funnily enough doesn't happen all the time and it is not noticeable on other type roads.I am running Bridgestone A/T 245/70R16 on the Colorado and Maxway 215/70R15 on the pop top.has anybody got any thoughts on what may be causing this?your comments will be appreciated,thanks.
Hurls said
02:25 PM Jun 16, 2014
Hi Subaru,
I have had similar experiences and I'm pretty sure ( almost positive) the effect is caused by the expansion strips in concrete roads and has nothing to do with your rig or tyres.
Hurls
05:58 PM Jun 16, 2014
I have had the same thing in the old Prado and agree with Hurls. Nothing to worry about I would say.
I think we are that used to the black stuff when we get on concrete we notice the difference.
justcruisin01 said
07:00 PM Jun 16, 2014
There are many concrete roads that feel they are corrigated & does make you wonder how they can get it so rough. A front wheel drive is even worse.
JC
Baz421 said
08:53 PM Jun 16, 2014
Hurls wrote:
Hi Subaru,
Hurls
Agree this is most likely answer,,, plus expansion gaps with no filler left in them.
subaru said
03:19 PM Jun 17, 2014
Thank you for your responses,maybe i shouldn't worry too much about it but it sure feels like we are in a milk shake mixer when it happens.
(not as if i have ever been in one)cheers.
08:57 PM Jun 19, 2014
Higher tyre pressures can make it worse..
How about ??
Checking tyre pressures esp on front to minimum recommended..
Phil C said
12:24 PM Jun 21, 2014
Just to put the cat around the pigeons, I had a ford focus many moons ago with the same issue, went to bob janes to be told the tyre was worn by bad steering alignment. I was mortified because the car was only 3 months old. They also told me that new cars do not get a steering alignment at manufacture (again mortified). So after an alignment and NEW tyre the road was a lot smoother.
Just putting it out there.
Safe travels
koalaboy said
09:10 PM Jul 10, 2014
Hi do the stabilizer /load bars help with this as we had it going to the gold coast and it was just can't unbearable thanks , o and we didn't have any stabilizer /load bars fitted
Hi Subaru,
Hurls
JC
How about ??
Safe travels
