Hi, anyone have any ideas on what to do to stop front bag end from flipping up when travelling? Someone has mentioned Stay Put Ties has anyone used them or anything else? Thanks
valiant81 said
11:45 AM Jun 14, 2014
Hi Quincey;
We used to have a 2008 jayco swan and had the same problem as you do. What i ended up doing is puting a couple of canvas eye lets ( brass ones ), one in each corner of the bag and used a occey strap to tie down the bag to the draw bar. Quick,simple,and it worked a treat.
chaslib said
07:58 AM Jun 15, 2014
Same problem and opted for the obvious .... Removed the bag whilst traveling and just slipped it back in if we wanted to use it.
Quincey said
09:21 AM Jun 15, 2014
Hi, thanks for the replies, cannot remove bag ends they are permanently screwed to the Swan.
chaslib said
09:46 AM Jun 15, 2014
Hi ... That's a bit of a bummer ... We regularly unscrew and remove them all to clean after each trip ... Seems strange that Jayco have such a user unfriendly system .... Guess the eyelets may be best on offer for you at this time ... Best of luck
Hi Quincey;
