I just replaced the 240V element in our Dometic 2350 3 way fridge and found that it was very difficult to remove and replace. The element seemed to be very tight in the chimney tube and took a great deal of wriggling back and forth, with considerable upward force, to remove it. I expected it to be a snug fit, but not this tight. Is this normal?
Bob
oldbobsbus said
11:34 AM Jun 1, 2014
Yep thats the way they are made as the heat from the element is transferred to the boiler tube by heat transfer through the mounting tube..
I have had them soo friggen tight I have had to destroy them to get them out..
ozjohn said
02:13 PM Jun 1, 2014
Life can be a bitch, and so can removing a Dometic element. Yep! They're tight. OJ
-- Edited by ozjohn on Sunday 1st of June 2014 02:14:38 PM
oldtrack123 said
03:29 PM Jun 1, 2014
HI
And if the replacemet is not a tight fit ,it will probably not last long!!
PeterQ
03_troopy said
05:35 PM Jun 1, 2014
Thanks guys.. yep the new one was also tight to fight.. not quite as tight as the one I removed, but to quote from Crumpy in the Hilux add, "its as tight as a snapper's" .. ...... and we all know that's watertight...
oldbobsbus said
07:10 PM Jun 1, 2014
Bob
Yep! They're tight.
OJ
HI
PeterQ
Sounds like you're on a winner mate..
