I recently bought a second hand Mercedes dreamseeker campervan and until now haven't needed to put water in.
I can unlock the cap but it just turns around and I don't want to get too savage with it until I find out what i'm doing wrong.
if it wasn't the easter break, i'd phone the company I bought it from.
help would be appreciated
take care and travel safely!
KFT said
05:17 PM Apr 19, 2014
Welcome Frednme,
I think you will find that if the cap just turns around you have locked it.
put the key in and turn it 90 degrees to where it is now and the cap should be able to be unscrewed normally.
frank
Plendo said
05:21 PM Apr 19, 2014
Fred, if it is the same as the Camec on our van it just spins around when it is locked. Insert the key, hold the cap, and rotate the key a quarter of a turn anti clockwise, and then the cap can be screwed out.
Hope that helps.
PS I only know because I asked the same question two days ago.
07:35 PM Apr 19, 2014
Yep, sounds like mine. What the others said is right for mine too.
frednme said
12:08 PM Apr 20, 2014
thanks to all the replies re the water cap. appreciate the ready responses.
hope to meet you on the road soon.
frank
Hope that helps.
Cheers John
