Looking at buying a portable toilet and have looked at cheep ones and thetford and want to know if thy are worth the extra money and what is the best pump ones the 165 is a squeeze one or spend more on the proper pump one
thanks
kiwijims said
01:35 PM Mar 28, 2014
Howdy Cowboy 7307,
We have used the "Porta Potty" Brand, both the 365 and the 465 models over many years,
We prefer the plunger type of flush system as the pull up and down type seem to loose the suction after a couple of hundred strokes.
This brand is pretty reasonable in price and we have had no problems with their use.
Cheers K.J.
Cowboy7307 said
06:21 AM Mar 29, 2014
Ok thanks
one more question
i have just measured the hole, toilet has to go into for travelling, and i can only put in the small unit ,but i do have room to but the bigger unit if it was split,toilet will only be used in a pop-up tent
my question is if i buy the taller one with 20lt holding tank can i split the unit in 2, and travel with both tanks having fluid in both
Radar said
11:05 AM Mar 29, 2014
Hi Cowboy,
I have slow about replying, this morning one of my chores was to do the job, empty, clean.
Well it made me think a little, at first when I brought my portapottie I was looking at the larger one, things like it would not fit in the given space, then this morning when I lifted it I realized I am glad we use the small cap one, even half full you will notice the weight.
I do like to empty it when ever a chance come by, we only use it for number 1's but now would not be without our friend. Cheers
hako said
11:22 AM Mar 29, 2014
No reason why you could not split the unit in two and carry them separately....actually that's a good idea! My bro-in-law never puts water in the top tank - prefers to use a squirt bottle to do the flushing as he reckons he can direct the water stream where it's needed....lighter to carry/move the unit as well as the top tank is empty.
Re brands - ours is an el-cheapo @ $59 as is bro-in-law's....his is over 6 years old and he uses it full time.
Good Luck.
aussietraveller said
12:19 PM Mar 29, 2014
I agree definately the smaller one, it is easier to store and easier to empty we had the smaller one for years in our pop top ours was a Thetford and now we have the larger van we also have the larger canister and I use the tug to get to the dump point.
hako said
03:45 PM Mar 29, 2014
Trouble with the small ones is that they are much lower and the older you get the less you like to squat. The larger ones are the same height as a conventional toilet. You could use a stand to raise a small one however.
Cowboy7307 said
04:56 PM Mar 29, 2014
just come back from getting a thetford 145 ,thats the small one, and a small step to put it on in tent, lifts it to about 500mm at seat so hope that does the trick ,
Radar said
07:41 PM Mar 29, 2014
Great work, best money spent specially if you have a lady, my lady is the best but this is special.
Radar said
07:43 PM Mar 29, 2014
Great work, best money spent specially if you have a lady like my lady, is the best but this is special for our needs.
thanks
Howdy Cowboy 7307,
Cheers K.J.
one more question
Hi Cowboy,
Good Luck.
