I am planning on living in a caravan without a town water supply. Can anyone recommend a hot shower system. I would probably set it up outside the van.
gunnago said
12:19 PM Mar 19, 2014
yoeleven has a good outdooystem called hot water on demand it is a coleman I think runs on gas
brian said
12:50 PM Mar 19, 2014
BCF have the Companion Cube gas water heater on special at present for $299, and they will also have a shower cubicle and other stuff if required.
Arthur you need to be a bit more specific .Are you in a park ?,or the middle of nowhere ? do you have 240 volts always ? Is it 100% never moved? I can save you a few bucks but fill us in . John
arthur said
09:22 AM Mar 20, 2014
It will be on a 1/2 acre building block-initially powered from only what I can provide (generator, solar etc). Don't intend to move it, maybe after the house is completed.
If it was semi-permanent then I'd go solar with this unit:
http://www.ebay.com.au/itm/Portable-Solar-Hot-Water-30L-tank-rooftop-caravan-camping-shed-/181352945270?pt=LH_DefaultDomain_15&hash=item2a397a5676&_uhb=1
