Guys we have sat dish with foxtel LNB and 2 cables.... previous had the standard analogue box for sat tv like most travellers have
want to use a foxtel standard box which we have at home and connect to the dish and to tv in the caravan
has anybody had a go at doing this and what results getting the signal
much appreciated if any one knows the ins and out
ozzimax
Big Gorilla said
03:00 PM Mar 10, 2014
I've often thought about this and have spoken to a Foxtel technician (Used to be Austar in Tassie) . He even offered to sell me a Foxtel dish. I didn't take it up because I'm a free camper and you need 240 volt for the Foxtel box. But I was assured by the technician it would work. He even had a set up in his Van doing the Annual Shows throughout Tasmania, selling Austar subscriptions, so I've even seen it working. I don't know if there is anything special about the dish or any dish will do. All you have to do is point it in the right direction.
ozzimax said
03:19 PM Mar 10, 2014
thanks ken at least someone knows it works
just need the Knowhow for finding sat direction in the bush
I use a gen so 240 not a problem
hope somebody has all the information
ozzmax
valiant81 said
04:24 PM Mar 10, 2014
Hi ozziemax;
You will not have a problem useing a second hand foxtell/austar dish for your television useing the Vast receiver. The vast set up uses the same sattilight as foxtell, so all good there. The hard part is finding the sattilight in the first place and after a few ? trial and errors you will become a old hand at setting up your dish, not as hard as it seems, but practice makes perfect.
Just incase you do not know, there are now on the market 12 Volt Vast recievers and of course there are also 12 Volt televisions, so no need for that pesky generator.
Just google 'sattilight set up for vast television' and there is plenty of imformation on what coordinants to set the dish up for what area / town you are staying in.
-- Edited by valiant81 on Monday 10th of March 2014 04:31:17 PM
KFT said
05:27 PM Mar 10, 2014
Ozzimax,
We have been doing what you want to do for a long time now. We run the foxtel box on an inverter(300W PSW)
We have a digital satfinder to correctly aim the dish and lock on to the satellite you can get them here: www.satplus.com.au look for the SF3239 about $140. one of these will make it easy to find the correct satellite as there are quite a lot of them up there.
I have attached a pdf of the aiming points for most towns in Australia but be aware the elevation angles given in this table are all 3 degrees high so subtract 3 to get the correct angle.
A magnetic compass to find north will be a great help also.
aiming can take a bit of practice so do some setting up at home before you hit the road.
any other questions come to mind just ask
frank
-- Edited by KFT on Monday 10th of March 2014 05:28:38 PM
am I correct in assuming that foxtel uses the C1 satalite
KFT said
11:05 PM Mar 10, 2014
G'day Ozzimax
Foxtel and VAST are both broadcast from the C1/D3 satellites which are co-located at 156 deg and roughly over the equator.
if you click on the pdf file I put in my last post you can download the current settings for C1. but read the note I have in that post about the elevations being 3 deg high.
I am off to bed shortly so a chat another day maybe.
We don't tell foxtel what we are doing as by moving the box away from your address you are breaching your agreement with them and they do not like it at all and may cancel your service.
frank
ozzimax said
07:42 PM Mar 11, 2014
Thanks Frank for all the info
noted the the co-odinates in your attachment are a lot different from the old
ones I used with the vast set top box I had but that was analogue
have done I hope an attachment of my ones you can see the difference
would I take a foxtel box away from home lol my lips are sealed
would still like a phone chat fingers get sore typing
Ozzimax, as others have done I've been using the system you propose for a couple of years now with the IQ box with 85 cm dish and can always get a signal.
Practice is the essence, which you have probably learnt from previous satellite experience.
Presuming you still have an account with the provider who owns the box I would encourage you to set up at home and have a few practice runs. The neighbours may think you've gone slightly off your rocker but I wouldn't let that phase you.
I carry the location sheets with me but don't use them since downloading 'WikiCamps' on my smart phone for about $5. Up until then I found the location data sheets great.
This very smart app. not only gives appraisels on campsites but has the 'satellite finder' application which points to the satellite and beeps but also gives Azimuth, LND and Elevation for the location in which you are standing.
I've just arrived home after a couple of weeks and one of the sites I was at I was amazed that a very small 'window' of sky could be seen through the tree canopy and had perfect strength and quality of signal.
Go for it ozzimax and good luck!
Keith.
wevs36 said
04:33 PM Jun 7, 2014
Wikicamps is a great little app for your smart phone or tablet , so easy to find Sat signels and of course free camps as well....There also an app you can get on your smart phone solely for satalite dishes if that what you need...
sorry had this in wrong spot
hope this is the Techies corner this time
ozzimax
ozzmax
Hi ozziemax;
Ozzimax,
frank
thanks for the info
actually the dish is the one I have used for about 10 years still good
just added the foxtel LNB which was given to me when foxtel was set up at home
we had a second set top box for games room that I want to use with the van its standard not IQ
dont want to buy another digital set top box if can use the foxtel one
just not sure of the sat positioning for foxtel have the Optus C1 sat set-up guide book
all information is a help thanks
ozzimax
Thanks Frank
its reassuring to know it works
get all sorts of y you cant by foxtel sales etc. such as they change the sat position every week
sounds good till you ask how they move the dish on my house roof to receive signal every week
I have used sat for about 10 years have no problem setting up the dish as long as have the co-odinantes
have old optus C1 book which have most co-ordinates
all I did was change out the LNB to a foxtel one which has two cables one picture and one for sound
frank
love to have a chat on the phone where are you at the moment travelling or home like me
we Live in Perth
ozzimax11@bigpond.com if you send me a number via email will give you a call
thanks again ozzimax
that $140 sat finder would simplify things
frank
ozzimax
Keith.
