Any Glazier will cut a piece of mirror to suit. Ozjohn.
-- Edited by ozjohn on Monday 24th of February 2014 10:15:11 AM
hako said
02:19 PM Feb 23, 2014
This link has them for $16.80 ea incl postage - they're ORA brand. If you get them cut they need to be very precise as they clip into a plastic seal all they way round....double sided tape won't work. Repco and Supercheap usually carry replacement heads of different shapes/sizes which whilst not exact copies they are similar. You can be lucky and but them complete on Gumtree or similar for under $40 a pair. http://www.oraproducts.com.au/spareparts.htm Good Luck
kiwijims said
03:01 PM Feb 23, 2014
G'day hako,
You're dead right about the mirror having to be the exact size,
they are only held in by the surround rubber, and that's only around 5-7mm in depth
I think I may have to make a template of the old mirror. as it's only cracked in two and then take it into Repco or ( not so ) Cheap,
just to see if they have one the same.
I see that Camec are selling them complete new for around $138.00 ea
So, as I bought two of them from the Sunday Markets this morning for $20.00 I am pretty well ahead at present.
You're correct PeterD they are the Camec brand, I rang them today about replacement glass,
You might have guessed the answer.... "Nup" can't buy mirrors, but they do have new Heads at $49.00 each.
I have emailed the Mob you mentioned Denis, just to see if the ones they have are the exact size,
which, by the way is 210mm wide x 135mm high,
so far they haven't replied.
kiwijims.
Cupie said
09:51 AM Feb 28, 2014
I had the local glass place cut one for me.
Just took the mirror head down to him & he cut & fitted it while I waited.
Can't remember what it cost but I think around $10 ..
G'day All,
Could anyone tell me where I can get replacement mirror glass for my extension mirrors ?
Glass for This is type of mirror x 2 is what I require........
Thanks kiwijims
Ozjohn.
Good Luck
G'day hako,
Cheers kiwijims
They look more like Ausie Truck mirrors to me or the Camec direct copy ones.
kiwijims.
.. no problems .... G
