HI all. our waeco cr-140 is on the blink. showing 3 red flashes, googled it and it says the rotor is jammed . the pressure difference in the cooling system is too high (> 5 bar).
turn fridge off for 10 mins and restart.
tried that but still nothing. any help would be more then welcome.
take care
Mick
DeBe said
04:02 PM Feb 22, 2014
This may sound drastic, but if it is a locked rotor & not too high a head pressure. I would give the compressor a few hits on the metal body with a hammer as power is applied, & see if that works. That's the cheep option, any thing else is going to be expensive (unless its under warranty) if it is I would be taking it to an agent.
03_troopy said
09:37 AM Feb 23, 2014
Yep, sounds like exactly what i had with mine. Turned out the compressor was knackered. And from the help he gave me with mine a while back, I can tell you that DeBe is quite an authority on these fridges, so he should know.
Mick Woolnough said
07:21 AM Feb 25, 2014
thanks for the info, will try the hammer thing. if not will find someone in Mackay on my next trip in
-- Edited by Mick Woolnough on Tuesday 25th of February 2014 07:22:14 AM
take care
Mick
