Ok just wondering if you can use an electric blanket on solar power??? We have one for the van but haven't needed it as yet but seeing as we have a low in the mid 20's overnight going to cooler weather in the next couple of months might be hard to take! doubt we would need one but curious ...
hako said
05:03 PM Feb 21, 2014
You could run it off an inverter as they don't draw much power if 240Vac. You can now get 12 volt ones and then you wouldn't need the inverter. We used an electric 'throwover' which is like a mini electric blanket but only to warm the bed before hopping in. Hot water bottles are pretty good too.
Kooroorinya Kelpie said
05:08 PM Feb 21, 2014
Hi whitey2 and all. Yeah mate you can but it will eat your power real quick. An electric blanket is just an element wrapped up and like your toaster, electric kettle, etc. is a power glutton. Extra aircell blanket and or a doona is much cheaper to run. When we were camping out in sub alpine regions everyone in the hunting party used to have 6 or so fist sized rocks which were placed around the evening cooking/camp fire and when it came swag time each bloke would juggle his near red hot rocks and put them each side of the swag. Kept you warm long enough to go to sleep. Never tried them in an Rv mainly because The Boss would probably disown me. Cheers.
valiant81 said
05:31 PM Feb 21, 2014
Hi;
Re the electric blanket idear, sounds good and the average electric blanket draws about 60 Watts, on high. With both sides on would be 120 Watts, not a problem IF you are connected to the mains power , but if running from a inverter and batterys, well i don'nt think your batterys would last the night . As it has been posted before, why not use a hot water bottle.
XTV said
07:13 PM Feb 21, 2014
This is a bit like how long is a piece of string.However, possibly:
·Two electric blankets require approx 120 watts from 230 volts.
·A 12 volt DC to 230 volt AC inverter at best would be 80% efficient, so would consume about 144 watts, or 12 amps from a 12 volt battery.
·A fully charged 100 Ah battery can possibly provide about 70 Ah before going flat. 12 amps may therefore be available for only about 6 hours maximum.
·So, if you have a fully charged 100 Ah battery (whether from solar cells or a generator) at best you would probably only manage about 6 hours before they were flat.If you have two fully charged batteries, you could possibly get 12 hours.
·The next day, the battery would be flat and need to be completely charged to allow you to repeat the process.
I agree with the suggestion to use hot water bottles!
Colin
KFT said
07:47 PM Feb 21, 2014
we have a 12v/LPG heater installed in the van so we don't need the electric blanket.
it works very well is quieter than a diesel heater and draws hardly any power at all.
we love it
frank
Peter_n_Margaret said
07:58 PM Feb 21, 2014
We have a double electric blanket in the OKA that runs via the inverter.
About 60W per side on high, but 30 minutes is plenty to warm the bed, then it can go off or to low for the rest of the night.
If it is really cold it is great to switch it on again in the early hours.
Total power usage is quite moderate.
whitey2 said
10:21 PM Feb 21, 2014
Thanks for the replies, firstly yes we do have hot water bottles, woollen underlay and probably no need for the electric blanket but ...... To warm the bed would be nice.
01:16 AM Feb 22, 2014
Depends on the person your with ??
07:36 AM Feb 22, 2014
I Reckon a medium size dog is a fair sort of a bed warmer, the hardest part is getting them to move when you want to get in. Dual purpose too, as they are our 46 tooth security system.
_wombat_ said
09:35 AM Feb 22, 2014
we use a hot water bottle (sometimes) most of the time we do the usual and then the covers have to come off cos we are too hot.
05:25 PM Feb 22, 2014
I reckon that if it is cold enough for an electric blanket to be a necessity then you probably need other heating as well. I'm with Frank install a diesel or LPG heater, that will warm you twice
08:19 PM Feb 22, 2014
I have a very cuddly hot water bottle called Billeeeeeee!!!!!!!
_wombat_ said
08:25 PM Feb 22, 2014
i've seen him
09:43 PM Feb 22, 2014
All I need to stay warm!!!!
03_troopy said
09:33 AM Feb 23, 2014
All we ever used in the camper trailer was a good quality sleeping bag under the sheets, on the mattress. A couple of blankets then another sleeping bag over the top as a doona. Kept us warm and comfy even in cold weather in northern SA and southern NT in June. How cold was it.. well we used to get ice forming from the condensation on the roof of the tent above our heads. And if you ventured out for a pee, in the middle of the night, you'd have to snap it off when you were finished ;)
brian said
12:19 PM Feb 23, 2014
I hope you meant the pee and not the old fella.
01:48 PM Feb 23, 2014
You need to be qualified for that ! It's not the old fella its the two nuts hanging out with him ...lol
_wombat_ said
01:51 PM Feb 23, 2014
the two nuts are not happy cos there is no thread to screw onto.
whitey2 said
09:02 PM Feb 23, 2014
hahaha thanks for all the feed back and laughs, will just be sticking to woollen doona and in emergency a hot water bottle to warm the bed. Cheers whitey2
Hi;
This is a bit like how long is a piece of string. However, possibly:
· The next day, the battery would be flat and need to be completely charged to allow you to repeat the process.
Colin
we love it
frank
i've seen him
