Is there such a thing as Water proof paint...Went to Bunnings today and they said Yes..But don't now about Leaks on Caravan or Coasters I 'm finding a couple more Leaks from the roof of my van and no Idea where it comes from And I need to know I figured to paint the whole roof of the Coaster........
06:44 PM Feb 19, 2014
Maybe a few coats of a good marine paint Jimbo will do the trick.
TAJ said
06:49 PM Feb 19, 2014
i would check all joints silastic hatches screws
could help before you paint
suenray
native pepper said
06:50 PM Feb 19, 2014
G'day Jimbo, there is a really good paint which is waterproof and is a very good roofing insulator. Came a cross a couple who had it on their 5th wheeler, said the difference was great and it didn't leak in heavy storms any more. It's was called envircoat I think. There would be a number of others.
You could also use a 2 pack marine epoxy, they are waterproof and can be sprayed painted or brushed. We use them on our motorsailer, makes a huge difference to sealing our jarrah deck, compared to corking, or sixaflex.
Yuglamron said
07:43 PM Feb 19, 2014
I have a friend who painted his whole roof with a thermoshield paint. It's a rubberised coating and needed two coats to get a good coverage. It solved some niggling leaks as well as dropping the temp inside the vehicle. He reckons it's well worth putting extra around hatches and other fitting on the roof.
Killed two birds with one stone.
As with any other hi tech or different type of paint not cheap but it worked for him.
oldbobsbus said
09:04 PM Feb 19, 2014
If you find one that permanently stops leaks after just painting it on patent it because you are on a winner..
You need to find where it is leaking and fix it... there are NO shortcuts..
09:18 PM Feb 19, 2014
Painted mates old caravan roof with kill rust white..painted with Roller then went over with fine brush in different directions.. You wouldn't know it was brushed on !! Yes I would use some sealer on joints where it's leaking.. First!
-- Edited by Aus-Kiwi on Wednesday 19th of February 2014 09:21:47 PM
jimbo said
09:06 AM Feb 20, 2014
Aus-Kiwi.....It would be so simple if I knew where the leak is I figured to paint the whole roof would be better in the long run...Got a feeling it could be around the Air Conditioner
WAssa41 said
09:48 AM Feb 20, 2014
Jumbo I had the same problem and painted the roof with a flexible paint that is used around shower bases before they lay the tiles and then put 2 coats white gloss top water based paint, all stocked at Bunnings. The gloss helps in reducing the heat from the sun. Not had a leak since.
regards
Wassa
hako said
12:01 PM Feb 20, 2014
I seem to remember on the old plywood vans that before painting and old van you located all the cracks, seams and questionable joints and then applied Aquadhere, waited till it was dry and then painted over it to seal it. The Aquadhere creeps into the cracks. Bondcrete would probably be the same.
TAJ said
07:33 PM Feb 20, 2014
the new regent i got years ago leaked in the air con the roof was dished
where a worker must have stood on the roof had to send it back to makers
to put new roof on with extra stiffeners in it done under warranty
After one coat I applied some Sikoflex where we thought there could be leak issues.. YES around air conditioner and joints ..
We saw some spray on rubber out of can but we already had some Sikaflex, so we use it before it went hard..
Cannot paint over normal silicon ..
The Killrust paint goes on very thick with roller and brush method..Mates grandfather showed us this technique
Sounds like back yard job which it definitely was .. The next day which was quite sunny and hot we couldn't believe how well it looked..
KevKim37 said
02:25 PM Feb 21, 2014
Regent Paints also make a Heat (Thermal) Reduction type paint Called "Heatguard" which ends up similar to a thick flexible coating ( needs two coats on a clean painted surface or if on fibreglass the surface has to be cleaned and a primer applied first then the two coats. Helps with sealing problem areas. I have had this product on our van and ute canopy since 2008 without any problems. Also available in different colours.
Cheers Kev
jimbo said
06:14 PM Feb 21, 2014
Thanks for all the tips..... I should find a cure for my problem somewhere amongst this lot
suenray
regards
Wassa
suenray
Cheers Kev
